Do I have a cooling fan issue?
BradV6 Jan 23, 2013
  1. BradV6
    BradV6 Member
    84
    It's a 3.2 2005.
    Each time I start the car the fans more often than not kick in straight away, even in these icy conditions.
    Also when I lock the car after its been driven and got up to temperature, mostly short journeys, the fans stay on for a good few minutes.
    Is there a known cause for this? Not really a problem but the fans are on a lot and it never used to be like it.
  2. NHN
    29,332
    1,716
    Coolant sender, get vcds on it & check measuring blocks, to see what its registering temps as.
  3. paulious
    paulious Member
    64
    Hi, I've just had a similar problem with my 54 plate A3 3.2. The fan only used to come on after a hard drive for a few minutes when parked up. That's perfectly normal but last week drove to work very sedately in icy conditions(about 12 miles). Parked up and noticed the radiator fan was making a hell of a racket, it was spinning at full speed which is louder than usual. Came back to the car 8 hours later and everything was dead. Jumper cabled it to a friends car and instantly the fan was on full power again.
    After some googling I instructed Audi to replace the fan(they come as a kit, one for A/C rad and one for main rad). The sensor is actually built in to the fan itself. £360 later and the problem has gone away.
  4. BradV6
    BradV6 Member
    84
    Wow! To be honest it's not giving me any battery problems at all and it doesn't stay on for more than i'd say 3 minutes after the car is turned off. It is really loud so apart from that I may just live with it, £360 is a lot of money for a fan even if it does come with the rad!
  5. BradV6
    BradV6 Member
    84
    Sorry to revive my old thread, but the problem is now worse.
    I have noticed poor fuel consumption lately as well despite the engine size!
    Obviously this fault has been ongoing all year and I haven't got to it yet, but tonight I the temperature gauge on the car has stopped working (sat at cold all the way home, but worked this morning) , and the rad fans are going full speed on and off, its really loud. I used to be able to stop it by putting "ECON" on (A/C) off, but now that doesn't work. Also the car is parked up and switched off and the fans are pulsating on and off every 20 seconds or so.
    Is this a coolant sensor fault or a fan fault as mentioned above?
    Think i'm going to have to pull the fuse as I won't have a battery left by tomorrow (anyone know which fuse this is?)
