do hids wear out?
electricracer Nov 2, 2008
  1. electricracer
    electricracer Member
    149
    my 99 s4 has the original oe hids fitted, coming home last night down dark roads found the lights to be honest ****. i had to fix one of the headlight motors recently and set them up afterwards so know they are adjusted correctly. but they seem to be not lighting the road up very far in front of the car. one of my other cars had an aftermarket kit fitted and i remember that being better, and gfs new auris is fantastic. is it just the old design of headlamp projector or do the bulbs degrade with age they are nearly 10 years old
  2. Oranoco
    Oranoco Well-Known Member
    3,924
    393
    Thi smight be a stupid question but your headlamps are clean aren't they. Dirty lenses can really impede the light output
  3. Siena
    Siena Active Member
    2,626
    I would imagine the Xenon bulbs have a limited service life, like any other component.
    First thing to check is that the projectors / reflectors are in good shape.
    I have OEM RS4 units on my car - one-piece, and the lighting compared to even higher wattage halogens is like night and day.
    I have heard though, some folk replaced their Xenon bulbs, and got better light output, so worth considering.
  4. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    Yes, the OEM bulbs output does degrade over time.
  5. Oranoco
    3,924
    393
    Any lamps lumen output will depreciate over time.
  6. electricracer
    149
    so do i replace with standard or are there upgrades available?
  7. electricracer
    149
    what are the replacement lamps part no? can you get aftermarket ones (ebay) what temp is the brightest?
  8. Blue_Thunder
    1,771
    31
    Go for a 4300K HID setup. 50-55W if possible. I've fitted aftermarket HID's to my S4.
  9. electricracer
    149
    from where???
  10. aragorn
    18,315
    808
    i've heard of a company called HIDS4U who seem to do both replacement OE bulbs and upgrade kits giving 35 (oe) or 55w output. (the ballast sets the output wattage afaik, not the bulbs)
