Do disc heat shields need to be there?
Newquaygreen Nov 23, 2013
  1. Newquaygreen
    Newquaygreen New Member
    14
    My disc heat shields need replacing but I was wondering if they are really needed at all. If I just removed them would it make any real difference to the cars braking performance?
  2. JimmyH
    JimmyH Active Member VCDS Map User
    374
    73
    Leave it alone, it's there for a reason. it prevents water, debris and general **** from damaging and contaminating the brakes.
  3. S3Alex
    10,770
    4,791
    The other side of Jimmy's comment is that mine have been removed a long time ago.....no issues at all.
  4. s3_sid
    s3_sid Active Member
    368
    35
    its main purpose to my knowledge is a stone guard to stop stones being flicked up and getting wedged between then pad and disk ruining you lovely expensive disks , unlikely to happen but still
  5. mjr901
    mjr901 Guest
    Infact they are just a stone collecter!!
    Stones wedge behind the disc and this guard and block up the vents of the disc anyway, and cause horrendous noise.
    If you take them off, leave them off I say.
  6. JimmyH
    374
    73
    I can safely say I have never had the issue of the disc guard collecting stones on any of my cars!?!
  7. bmh.01
    bmh.01 Member
    291
    17
    Not ultimately necessary, remove if you will. A lot of cars don't have them at all.
  8. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,679
    2,573
    On ETKA they are described as splash shields so the manufacturer puts them there to try and keep water from the brakes.
    If they didn't do anything then the manufacturer wouldn't put them there. I did remove them on my Passat when I upgraded the brakes to larger discs and never noticed any real difference except occasionally in the winter when there was a lot of slush around and the brakes were cold there would be a bit of a delay before they started working. Possibly due to the whole braking system being waterlogged.
    karl.
    Artimus and JimmyH like this.
  9. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    My front ones have mostly rusted away anyway
  10. Sevv
    Sevv Pushing the limits..
    1,324
    120
    i have taken them off and they are staying off and never had any problems, only thing is your more likely to get more brake dust.. bonus side is one less item bolted to the car and less weight (even though they arent heavy but still)
  11. JimmyH
    374
    73
    total weight saving of about 600 grams, personally don't think it's worth it .... Better option that'll save you more weight is go to the toilet before you go for a drive :)
    CHEZ and Sevv like this.
  12. Sevv
    1,324
    120
    lol, that must be one hell of a visit to the toilet haha, but if you think about it you can go to the toilet and loose the shields and you'll have extra weight of the car :p
    JimmyH likes this.
  13. JimmyH
    374
    73
    Haha, mega toilet visit.
  14. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    I had no choice all 3 bolts both sides snapped and haven't had rear guards on for some time. No adverse effects yet
  15. Artimus
    Artimus Shortback
    2,016
    485
    Don't they also minimise heat soak from the disks into the brake lines, helping to avoid boiling brake fluid\brake fade on track days\spirited drives?
  16. desertstorm
    5,679
    2,573
    Sometimes they will provide protection to ABS sensors and the like from direct radiated heat. On the Passat , when I removed the front shileds I cut a small piece of aluminium and secured it to one of the bolts to stop any issues.
    Karl.
