Do Audi's use oil?
Iceash May 3, 2012
  1. Iceash
    Iceash Member
    391
    10
    A lot of people I speak to say "Oh Audi Engines do use a little oil" I've just done around 1100 miles since owning around 100 of though's towing a caravan. I'd just used a smidge off the maximum so I'm pretty pleased. Just wondered though if everyone else find their "Audi's" use oil?
    I'm running a QTS AJL engine on 124'ish thousand miles on the clock.
    Just passed it's MOT with flying colours and certain lights fitted!?!
  2. Iceash
    Iceash Member
    391
    10
    anyone?
  3. Turbo unit
    Turbo unit Member
    93
    Mines the same every couple of weeks i check mine audi say its the design of the engine to burn 1 litre every 2500miles
  4. andyw82
    andyw82 Member
    46
    mine went from full on the dipstick to min in about 6 months, only noticed owt from the exhaust 3-4 times on idol, done bout 3500- 4000 miles tho, its all good. ;-)
  5. Turbo unit
    Turbo unit Member
    93
    :icon_thumright:
  6. audiv8quattro
    audiv8quattro Member
    443
    9
    To be honest I never really check my oil now, I used to check it all the time and it never seemed to go down so now I just do the oil change every 6000-7000 miles and leave it unless I'm going on a really long journey ,and it's never dropped below half way between full and empty
  7. Turbo unit
    Turbo unit Member
    93
    thats about 1litre of oil there!....Some burn more than others you got a good 1:beerchug:
  8. Iceash
    Iceash Member
    391
    10
    Yea I'm pretty pleased and as I tow a caravan thought that was spot on. I'd only noticed cos the low oil warning light came on for some odd reason. it had used maybe an 1 8th of the stick and that was a hot check.
  9. Vince70
    Vince70 New Member
    17
    My car is a 1995 1.6 petrol A4 and in the year or so I have owned it I have never used a single drop of oil.
  10. Iceash
    Iceash Member
    391
    10
    That's really good going, I'd keep it if i was you :)
  11. jamie226bhp
    jamie226bhp Member
    468
    Sure that was the low oil light and not low oil pressure as these engines do suffer from blocked pick up pipes
  12. Iceash
    Iceash Member
    391
    10
    it was the amber warning with low or min next to the oil can. It went out once I pulled over.
  13. Vince70
    Vince70 New Member
    17
    Does anyone know if the 1.6 suffers from the same problems as the 1.8 with oil starvation problems due to a blocked oil pickup.
  14. Iceash
    Iceash Member
    391
    10
    well I've done 500 miles, including 150miles of caravan towing and it seems not to have used a drop! :-D
  15. Iceash
    Iceash Member
    391
    10
    well I reckon I'm using just under half a ltr per 1000 miles. Still not too bad. Love to know where it leaks to burn it? Going to try some seal reñovator see if that helps
  16. aragorn
    18,663
    878
    valve stem seals and turbo typically.
  17. Iceash
    Iceash Member
    391
    10
    Fixable or not worth it?
  18. technics100
    technics100 Active Member
    850
    25
    I have had 8 VAG cars, 6 of which have been Audi's. I have only ever had to do the odd top-up between services.. A fella I work with has a E93 325i M-sport, it uses a litre every 700 miles steady.. which is about 14 litres a year, BMW say its within tolerance!!! VAG FTW..
  19. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Both my 2.5TDis use almost none.
    The Avant has a slight (I think heavy!!) leak from the injector seals/rocker covers and sometimes uses up to a litre in 10,000 miles. (Vege engine, 30k miles old - leakage down to me :crying:)
    I haven't topped up the saloon between services (three 10k mile services since I owned the car), and it's on 122,000-ish now :arco:.
  20. Iceash
    Iceash Member
    391
    10
    Wonder if anything can be done to improve the usage?
  21. RYes3
    RYes3 Active Member Team Nardo Audi RS3
    919
    198
    43
    Just put 200ml in my brand new S3 after nearly 4K miles! I'm well impressed if I am honest!
    Iceash likes this.
  22. Iceash
    Iceash Member
    391
    10
    I just don't like you lol
  23. RYes3
    919
    198
    43
    Lol, sorry :)
  24. Iceash
    Iceash Member
    391
    10
    Wanna swap?
  25. RYes3
    919
    198
    43
    No, I can't afford the oil in yours :)
  26. Iceash
    Iceash Member
    391
    10
    I'll give you 5ltrs for free to get you home lol
  27. RYes3
    919
    198
    43
    Haha deal :)
    Iceash likes this.
  28. murran
    murran Well-Known Member
    1,545
    39
    i realise you posted this back in may, but to answer your question.....
    no not usually. just the turbo petrol engines in my experience.
    mainly because turbo engines should by rights be changed more often than due to the higher oil temps, high combustion temps, more piston blow by.... all these contaminate the oil faster. and when not serviced every 5-7k the carbon builds up till it starts flakeing off and swimming round with the oil until it blocks the pick up strainer.
    but still it can happen in n/a engines i suppose..... but youd have to be very slack on servicing it for a long time.
