Do Audi sale Replacement coil pack harnesses
dre_S3 Aug 31, 2012
  1. dre_S3
    dre_S3 Member
    756
    39
    finally found my problem with the car holding back me thinks
    do audi sell these harnsses in one or separate, im also im **** with electrics is it hard job ? is it cut and join or will it go straight to the ecu ?
  2. Greg-S3
    Greg-S3 Active Member
    576
    67
    Ring Milton Keynes TPS on 01908 625000 and ask for Mat, he is a very knowledgable bloke he will know all about if you can get sections etc and if comes as one piece and so on mate. Hope that helps!
    Or maybe try a auto electrician as they may be able to repair the damaged loom and make a good job of removing the plug and re joining the wires and plugs etc! Hope that helps
  3. Golfer1991
    Golfer1991 Member
    60
    Awesome gti sells them ;)
  4. Andrew@A.L.D
    3,879
    617
    if you have a level sensor in the sump then you need 1J0 971658 M the loom wires differ in colour but if your careful you should have a problem
  5. <tuffty/>
    21,235
    3,877
    Audi do sell looms but they are generic ones from all the ones I have seen... they are more like a3 looms than s3 ones... I fitted one to mine recently and just cut the wires and soldered the new ones on.... here is the bit in my build thread...
    http://www.audi-sport.net/vb/a3-s3-...9-my-minor-modding-thread-40.html#post1625906
    It not a comprehensive guide but you get the idea... I didn't buy the loom with the sensor as all I wanted to change was the coil pack part... worked out a bit cheaper that way...
  6. dre_S3
    dre_S3 Member
    756
    39
    How much was the harness mate and what was the part number Tuffty
    cheers mate
    Dre
  7. <tuffty/>
    21,235
    3,877
    Part number should be the one Andrew posted earlier and was around 20-30 quid... can't remember the exact price as I get trade from TPS anyway but budget for that..
  8. dre_S3
    dre_S3 Member
    756
    39
    Ok mate just been up TPS to get my clutch pedal and there have ordered me a harness it was around £30 so hopefully get it within the week thanks for your help :)
  9. dre_S3
    dre_S3 Member
    756
    39
    Anyone know what the harness from awsome gti is like? it goes straight to the ecu but can it be cut ?
  10. <tuffty/>
    21,235
    3,877
    I would imagine its the same as the OEM mate... if its a wire it can be cut ;P
    The OEM one is supposed to go to the ECU too...
  11. dre_S3
    dre_S3 Member
    756
    39
    Ok thanks Tuffty May just order it from them as tps have to get it from Germany could be up 2 weeks :(
  12. <tuffty/>
    21,235
    3,877
    !!! they must have run out then... fairly typical though...
  13. dre_S3
    dre_S3 Member
    756
    39
    Yeah just ordered one from awsome just need to get someone to fit it as my soldering skills are not that good lol
  14. <tuffty/>
    21,235
    3,877
    Make sure its a fairly powerful soldering iron for the thicker power cables else you will get bad resistive joints causing other issues...
  15. dre_S3
    dre_S3 Member
    756
    39
    Yeah think I will let a pro at it, can't be dealing with more problems if I muck it up
  16. AG205
    AG205 Member
    Did mine recently, lopped out the cracked wiring as far back as needed and just spliced the new coil connectors/earth in via soldered and heatshrunk joints. Just did one wire at a time to make sure everything went back in the same place and jobs-a-good'un. I used the loom from Awesome GTi (ECS Tuning sourced) and it arrived in a proper VAG box which was reassuring although it's certainly not plug and play on the S3 unfortunately.
    All my coil connectors where broken and the thicker wires were cracked pretty badly so definitely needed doing.
