dmf failure
yendall24 Sep 7, 2008
  1. yendall24
    yendall24 Member
    571
    9
    hi i was wondering if any body could describe the symptoms of a failing dual mass fly wheel ie is it like a normal clutch slipping and engine speed increasing without going any faster is there any noises associated with dmf failure any info would be welcome
  2. Broken Byzan
    13,244
    468
    The DMF tends to get very noisy on uptake of load, and when they fail complely you lose all drive iirc
  3. Andy.B
    Andy.B Member
    401
    I had a DMF fail on me in my Mrs's car, suffice to say it sounded like the bottom end of the engine had destroyed its self it had massive judder and clattering.
    Upon inspection the flywheel face had seperated form its rubber mounting to the rear flywheel and had rotated over the bolt caps to remove the unit.
  4. jcb
    jcb Active Member
    4,132
    13
    noisy as hell, no smooth engagement of the clutch
