DIY Stage 1 Map ?
A3 T Jul 24, 2011
  1. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    The tool is only used to read/write the map file on the ecu.
    You would then need software on your pc to edit the file.
    I don't think i would try and modify the map myself as its not as easy as just turning things up. If your taking it to “professionals” then they should already have everything needed to map the ecu for you ;)
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Providing the ecu is the same, yes it is possible. It's called cloning. People do it so the always have a spare ECU incase they brick there's while trying to self tune/modify there own maps.
    For anyone interested here is a list of software, cables and websites I have used/researched etc.
    Cables:
    Galletto 1260
    Vagtacho 3.01
    Vag+commander
    Vagcom
    Software.
    Galletto
    Nefmoto
    Vag+commander
    Vagtacho
    Vagcom
    Winols
    Tunerpro
    mapanalyser.
    Websites.
    Nefmoto
    Chiptuners
    Tdiclub
    Ecuconnections
    S4wiki
    From experience petrol turbo engines are pretty complicated stuff to self tune, but it is possible. TDI's are pretty straight forward. I would almost certainly say if you fancy doing it yourself. Give it a go, but please buy a spare ECU to practise on! and also bear in mind it'll take you hrs and hrs to get anywhere near a pro tune if you DIY, so you have to ask yourself is it worth it. But if you can get hold of an already tuned file and flash your ecu it'll take minutes and save £'s.. but there's not really much fun in that.
  3. Pedrosousa
    Pedrosousa Member
    174
    For me this isn't the right ECU to start with. Has lots of 8bit and 16bit map, the axis aren't easy to find an determine, lots of conversion factors.... Using ECM you will mess it all, with winols it's very hard and it takes many time! The Damos and ect... Help but you have to know what does every map and how they co-relate.
    Galletto it's good I used in the EDC15/EDC16, and it works good and in ME7.5 it scares me a little bit but until now without a problem... (clone tools talking).
    I can't use Nefmoto I don't understand why.....
  4. Chlippo
    Chlippo Member
    679
    15
    can anyone name a software that can be used to modify the map ?
  5. beachbuggy
    1,931
    202
    Tunerpro and winols. Tunerpro works well if you have an xdf for the .bin otherwise winols will graphically and numerically show the map but you need to know the locations and axis of the maps to work them.
  6. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Pretty much what I'm interested in. Taking a mapped car with the same engine and just copying a map from a big tuner. Frowned upon I'm sure but if it's possible then why not?
    I await all the comments saying how much tuners put into R&D and so on but a lot of them just write a generic file to the ECU so why not DIY if you can get the file.
