DIY S3 Front wheel bearing....
Welly Dec 16, 2009
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    128
    How hard are these to do...
    I've done a few in the past but mainly on Vauxhalls.
    Do the new bearings need pressing into the hub, or does the good old hot water method work? LOL :)
    Any thoughts appreciated...
  2. Crazypete00
    Crazypete00 Active Member Audi S3 Audi A4
    495
    61
    i would say you need a press......
  3. <tuffty/>
    21,162
    3,838
    I concur.....
  4. Welly
    10,696
    128
    Ok, thats fine. My good old fork and spoon method won't work then!
    Glad I asked before taking the hub assembly apart!
  5. 666markyboy
    666markyboy Well-Known Member
    1,211
    49
    You deff need a press.... i managed to do mine at home but it was a real struggle even with some homemade tools and a blowlamp
  6. HTC
    HTC Active Member
    3,428
    9
    Take the hub off and get down to your local garage. Have them press the new bearing in. Should only cost a drink. Will save loads of bashing and swearing.
  7. 666markyboy
    1,211
    49
    It's not so much getting the new bearings in.... if you warm the hub in say the oven and chill the bearings in the freezer then you can tap them in with the outer of the old bearing.... never tap the middle you will ruin your nice new bearings if you do..... the hard part is removing the old outer part of the bearind from the hub.... mine were rock solid stuck and also had to grind the center of the old bearing to remove it from the center part of the wheel hub.... biatch of a job...
  8. Welly
    10,696
    128
    That sounds like a right pain in the chuff. Bugger that, I'm off down the garage with the hub! My mate's garage is a 2 min walk, so he can sort it out and call it my Xmas pressie :)
  9. <tuffty/>
    21,162
    3,838
    ...gets my vote... I did this with my A4...
  10. kitpayne
    kitpayne Member
    129
    I went into a tyre place and asked if i could use their press and they were fine. Didn't ask for nothing. let me use their cir clip pliers as well.
