DIY Oil Change A3 TDI
karbonk Jan 23, 2010
  1. karbonk
    karbonk Living a little!
    182
    I had my head gasket changed recently and its due an oil change only. Audi quoted £100, Kwik Fit - £49, so decided to do it myself as it cant be that hard is not so important to have this one on history.
    As I cant seem to search the forum for previous posts (disabled). I was wondering if anyone has a link or can give me a run down of what I need to do. Is the Oil Filter recommended to be changed? What oil should I use, make and type?
    cheers :icon_thumright:
  2. vw754
    vw754 vorsprung Durch Technik
    2,357
    59
    must change oil filter aswell and i recommend a new sump nut as it comes with a built on washer (about £1.10 at audi) and use 5w-30 PD OIL ONLY ! . As long as its pd oil you should be ok,you can buy it from vw £15.50 + vat standard pd oil or £49 for longlife
  3. karbonk
    182
    Cheers vw754. How many ltrs is needed to do a complete change? May be worth getting someone to do it for £50 if it inc all the bits and wonder what oil they would use and inc a filter?
  4. vw754
    2,357
    59
    3.8-4.0 with filter,..........the questio is......will they use the right oil,or the oil u give them or there own?...........do it ursel or wait and watch ! i dont trust alot of em........down to bad experience.....what area you live in?
  5. karbonk
    182
    Yea true. Im in west sussex Area.
  6. gaz88
    gaz88 New Member
  7. karbonk
    182
    Easy as that? I thought diesels were somehow different. Wheres the oil filter located? does this need to be changed when all the oil is out? :icon_thumright:
  8. sijones
    sijones Member
    160
    When the head gasket was done they should have changed the oil too, you sure you need the oil change?
    Oil filter is at front of engine, change it from top, not underneath. it's a black round container with a 32 (or 36mm can't remeber) socket needed to undo.
  9. karbonk
    182
    Head gasket was replaced and new oil was used but after 300-400 miles after it needs changing again im told.
  10. karbonk
    182
    Im guessing a Oil Change is needed to be done after a replaced Gasket? Is it recommended or risk free?
  11. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    I use a Pela 6000 pump to remove engine oil then just refill with new oil and filter when finished. It`s a very quick,clean,cheap and simple way to change engine oil. http://www.pelaproducts.com/
  12. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    @ karbonk: Changing oil and filter is quite easy.
    First, you need to be able to get under the car, so you need some stands or something to lift the front of the car a bit.
    Remove the plastic cover, and find the bleeding bolt. Remove the filling cap on top of the engine ang go back under the car, with a recipient (5 liters capacity) and remove the bleeding screw letting the oil poor into the recipient. You may also remove the dip stick.
    When the oil is drained, you should remove the old oil filter and put the new one . This is the most difficult part because there is not much room around. I recommend you to grease the gasket of the new filter using some of the new oil.
    Put back the bolt in the bleeding hole, put back the dip stick, put back the cover under the engine and loer the car. Poor some 3.5 liters of oil (this is if you don't know exactly how much oil is required). Check the oil level then on the dip stick an poor some more until you reach the maximum level.
    Start the engine 2-3 minutes so the oil can fill the filter too then let the engine off for about 10 minutes. Check again the level on the dip stick an poor some more if needed. you should not put more oil than needed. start with the 3.5 liters. Its ok to start with.
    K.A likes this.
  13. karbonk
    182
    thanks for the detailed write up. Thats a great help.:icon_thumright:
  14. karbonk
    182
    Wheres the best place to buy the Oil Filter, Oil and plug?
  15. alfiejts
    alfiejts Member
    352
    I get mine from my local "motor factors" - "Partco". If you look up motor factors in the yellow pages, its where the trade buys their servicing stuff and you can usually walk in and buy from their trade counter and trade pricing.
    You want to make sure the oil is marked "VW 507.00" compliant. That's the 5w-30 fully synthetic oil that meets the "long life" specification.
    Don't buy any other cans with any other spec on it - even other VW specs as they aren't necessarily the long life specs.....
    I picked up a 4.5 litre can for about £18 last time... The guy behind the counter says "that's dear stuff that - are you really sure you want that one?"....
    I smiled and handed over £25 for a gallon of VW spec oil and a filter.....
  16. karbonk
    182
    :laugh:
    Cheers will have a nosey about. Nice one! :thumbsup:
  17. RS_Cosworth
    RS_Cosworth Member
    124
    Been getting my oil from here for years matey:- http://www.opieoils.co.uk/ Top service everytime! Click on the "Recommend an Oil for my Car" link on the left hand side of the page & you can't go wrong :icon_thumright:
  18. karbonk
    182
  19. slizza786
    slizza786 Active Member VCDS Map User
    402
    27
    Hi sorry to bring back an old thread. I'm looking to change my oil on my bkd engine 2.0tdi a3 but don't know where the sump plug is located. Iv attached a picture of what I may think it is. Is it this?
  20. c_w
    c_w Well-Known Member
    1,169
    91
    Yep, that's the one.
  21. slizza786
    402
    27
    It so difficult to unbolt. Even with wd40 I wasn't able to. I'm thinking of just using the suction machine instead
  22. SmithyAG
    SmithyAG Active Member
    414
    61
    Are you doing it with the car warm or cold? It's normally easier when there's hot oil in there. However this carries its own risk of burning you when you remove it!
    Last oil change I did at a mates house and had driven 20miles to get there so it was nice and hot under the car. Let it stand 10 min and then did it and it didn't burn me. So just be careful and you'll be fine.
  23. fangio
    fangio Well-Known Member
    1,550
    188
    You should only change the oil when it's good and hot!
  24. SmithyAG
    414
    61
    That was my belief too, as it means you get more of it out of all the oilways etc as it's nice and runny, and not a cold sludgey consistency lol
  25. slizza786
    402
    27
    How much oil is needed in the tank to max it out for a 2.0 TDI?
  26. SmithyAG
    414
    61
    3.8-4l with filter. I'd start with 3l and work from there checking on the dipstick.
  27. slizza786
    402
    27
    Cheers again smithy. I warmed the car for ten mins. My mates has changed the oil on the past before from the sump but looks like he has proper 'welded' it back on! So what i have done is ordered a suction kit that should arrive next week and just do it from the top. I read about that 3.8 is the max but Il do what u say and start from 3 as it makes sense
  28. slizza786
    402
    27
    Reminds me of trying to clean the damn turbo lol!
  29. SmithyAG
    414
    61
    Ha yeah I know what you mean.
    The suction idea is a good one, you don't even need to lift the car up to do an oil change that way.
  30. dk1234
    dk1234 Member
    223
    What suction kit did you buy? is using a suction kit just as good as doing it the usual way?
  31. slizza786
    402
    27
    Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=180856333737
    It should be good enough. You probably will just have to rummage the tube around the tank when it gets empty unlike the sunk hole where most just drains all out straight away but it prevents u from all the hassle of going under the car and getting all dirty
    dk1234 likes this.
