* DIY Injector cleaning how to * Pic Heavy
s3dave May 14, 2011
  1. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I thought i would start a new thread for this, so it does not get lost in the other one.....
    This is a guide to ultrasonically clean your injectors, plus fuel pressure regulator... AKA, FPR thats what i will be calling it on this how to, for obvious reasons.
    I have tried to do the how to, so a completely clueless person can understand, so dont think im being patronizing ....lol
    Safety first,,,,you are messing with the fuel system, there is likely to be a little fuel lost in this process, so bear that in mind....
    So to start off this is the fuel rail, where all the attention will be
    By d121m at 2011-05-14
    and the FPR...
    Start off by unclipping the electrical wiring loom
    There are 3 clips holding the loom to the rail and simply push off
    Next is The FPR pull the hair clip type thing away from the FPR.... Then pull the vacuum pipe of the FPR
    Then get a cloth and put it over the FPR then twist and pull at the same time,(be prepared for some fuel spillage) it may be tight and require some patience but it will eventually give in, put it somewhere safe for now.
    next is to get the little clips off the top of the injectors that hold each connector on,
    a bit fiddly, i got a small screwdriver and eased them up, make sure you dont drop anything as it will be lost forever.....put all 4 safe and pull the connectors off each injector,
    Next is to remove the rail from the manifold...(it is still connected by the fuel pipes no need to touch these)
    there are 2 cap head bolts to undo (again make sure you dont drop them)
    and the other one...
    After these are removed and kept safe its time to pull the rail up with the injectors,
    once free of the manifold you can get to the injector clips (yes more clips) these simply slide out
    a pic of one out....
    take all 4 out and keep the safe, then pull the injectors out of the rail, sometimes the O ring keeps in the rail ... just hook it out and put it back on the injector
    once all 4 are out you are ready for the fun part....Bath time...
    injectors before their clean
    Next prepare your ultrasonic cleaner....
    I used very hot water and a cap full of james sea solution and put the cleaner on max 480 secs
    Get the injectors in along with the FPR and watch the **** come out of them...
    when it is finished the water looks like this:
    Take them all out and shake then let dry for half an hour or so,....Clean injectors!!
    Refitting is a reverse of the how to, being careful not to lose anything make sure everthing goes back the way it came off, start the car and check for leaks.....
    My car took a lot of starting (well third attempt) this time round must have got a bit of air in...
    so dont worry if it does not fire up as usual when first started...
    TOOLS NEEDED
    allen keys
    small screwdriver
    small pliers
    ultrasonic cleaner + fluid Ultra 7000 Ultrasonic Cleaner : Ultrasonic Cleaners : Maplin
    *on offer at the moment*
    little vid showing the cleaner doing its magic....
    http://img837.imageshack.us/img837/9379/8jp.mp4
    G60DAN likes this.
  2. Plunky
    Plunky Member
    522
    Nice one!! im sure this will help a lot of people! did you notice much difference after the cleaning?
    Did you change the o ring seals on the injectors?
  3. s3dave
    10,110
    736
    I did notice the first time round..... not much today its only been a few months though, i did it for the write up today as a lot of people are asking for one...
    my O rings were not changed and did not need changing to be fair...
  4. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,269
    2,090
    Cheers Dave,mine going to be done Thursday.
  5. s3dave
    10,110
    736
    No worries mate.. maybe put in the a3- s3 stickies? how come you disliked the post above....:think::lmfao:
  6. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Its the injector seats that leak more than anything, not the seals.
    Im going to get my ultrasonic cleaner tomorrow seen as its on offer.
  7. voorhees
    16,269
    2,090
    iPhone mishap Dave :/
    Yes a sticky sounds good
  8. Sanj
    Sanj Blue Beast
    175
    your a legend Dave!
  9. LiveWire
    LiveWire S3X
    329
    I guess they arnt stock S3 injectors? mine dont have the tubes on the bottom :think:
  10. s3dave
    10,110
    736
    No.... 380cc from 225 TT needed for my stage 2 APR
  11. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    188
    Legend Thanks Dave im getting my bath tomorrow :rockwoot:
  12. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Great write up Dave! Top bloke.
    This thread was worth it for me simply to know the cleaner is on offer! Just bought one and saved £20!!! Class!
  13. jojo
    29,001
    3,657
    Good work Dave as usual.
    Cheers!
  14. talentwalsh
    talentwalsh Member
    139
    Dave, just a quick one. Would ultrasonic cleaning sort a leaking injector?
  15. s3dave
    10,110
    736
    you could try it if it is gummed up...nothing to lose...
  16. SiGainey
    SiGainey Member
    506
    10
    Anyone in the north west happy to help me with an experiement? I want to try ultrasonically cleaning my injectors in one of these maplin machines, then get the spray patterns checked then cleaned on an ASNU machine to see how clean they actually get them :)
  17. talentwalsh
    talentwalsh Member
    139
    True, cant harm it anything. Must invest in one of those cleaners.
  18. S3Lol
    S3Lol Member
    422
    wahay, I have something to tinker with at the weekend!
    Maplin site is down at the moment unfortunately!
  19. rhubarb4
    1,754
    188
    maplin ultrasinic clenert ultra 6050 £19.99
  20. S3 Nattie
    1,599
  21. s3dave
    10,110
    736
    Yeah 17th it ran out...
  22. voorhees
    16,269
    2,090
    I went for the one with 500ml of sea clean which was 30 quid Nattie
  23. S3 Nattie
    1,599
    Oh yes, forgot to get the cleaning solution.
    Anyone know where I can get some sea cleaner or whatever should be used.
  24. voorhees
    16,269
    2,090
    Ermmm Amazon :slapped:
    I did mine today and they were filthy
  25. S3 Nattie
    1,599
    I was thinking of somewhere I could walk to like a supermarket of something.
    Your cleaner has come already. How does the car feel
  26. voorhees
    16,269
    2,090
    I haven't driven it for a distance but mpg seems to have improved,loads of gunk come out
  27. S3 Nattie
    1,599
    Hope my mpg increases. Ive run my car on vpower all the time which is meant to clean your injectors to so be interesting to see how much gunk comes out.
    Just found some JPL sea cleaner at Maplins so going to get some. Sorry if this has already been said but do you fill the bath with warm water and add a ceratin amount of the sea cleaner to it.
  28. voorhees
    16,269
    2,090
    I used to until they started having supply problems
    A capful per 200mls I did two and also add a dash of washing up liquid in the first clean as they are bound to be filthy.
  29. s3dave
    10,110
    736
    Did everything go to plan Jase...?
    @Nattie i used very hot water...
  30. voorhees
    16,269
    2,090
    No Dave,I used ETKA to get seals and it shows BAM having two different ones,fitted them and the lower ones were loose (suspect straight away),but went ahead and had a whoosh and it was surging so put the old ones back on and sweet.
    Very filthy water though...have I said that already :)
  31. S3 Nattie
    1,599
    Cheers Dave. How long would you advise to leave them in for.
  32. s3dave
    10,110
    736
    I left them in for the max 480 secs....and a bit more for good luck
  33. S3 Nattie
    1,599
    Cheers Dave. Il feedback once ive done it.
  34. voorhees
    16,269
    2,090
    Damn...I left mine in for 8 minutes
    deeman88 and a3Nate like this.
  35. S3Lol
    S3Lol Member
    422
    mine have just had their bath. VERY dirty, but rings look all good. had to clean them once with cap full, then a further 180s with frest water washing up liquid (still **** came out), and then cleaned the outside by hand (bit oily) and a further 180s. slight crack in the orangy plastic ring at the bottom of one injector though (present when i took it out, nothing to do with cleaning). Any one else come across this? its not snapped, just a bit of a crack
  36. S3Lol
    S3Lol Member
    422
    Has anyone had GREAT difficulty putting the fpr back in?? mine is refusing and im nearly to the point of putting my weight on it. Dont want to break the rail though so if anyone can suggest other means, that would be great.
  37. S3Lol
    S3Lol Member
    422
    no problem, managed to get it on in the end. Might of been something to do with letting them dry in the sun and the rubber o-ring expanding a bit.
  38. Dani_B19
    9,465
    435
    What are these seals on the injectors i keep hearing about? Ive read somewhere about there been two seals to an injector, is this just reffering to the top o ring and bottom o ring that sits into the manifold?
  39. Inertiauk
    Inertiauk Active Member
    575
    29
    I think so Dani
  40. Dani_B19
    9,465
    435
    Thought so, i think mine maybe on the way out. Anyone know the part numbers cos ill changed them the same time as cleaing them.
