DIY Help!!
Randomjim Mar 21, 2008
  1. Randomjim
    Randomjim Active Member
    2,752
    Decided to put a punchbag up in my garage. Drilled into the wall, inserted rawl plugs. Lined up the bracket and started to tighten up the screw\bolts. They all snapped when they started to get tight. Went an bought more. Re-drilled etc and they did the same. What am i doing wrong?
  2. karl7900
    karl7900 Active Member
    1,392
    Sounds like your using the wrong size of drill bit, rawl plugs or screws. The size and length will depend on the weight of the bag and the hammering it is going to get.
    If you are using red Rawl plugs then a 6.0mm drillbit and 8x1 1/2" screw should do. Also when you are drilling, just drill the hole once. Don't be reaming the hole to make it bigger.
  3. Randomjim
    2,752
    I'm using a 10mm drill bit with m8 screws. The ones supplied are about 3 inches long. I'm gonna try buying some shorter ones. The rawl plugs are white or sorta see through really.
  4. karl7900
    1,392
    Try using masonry screw bolts. You drill the correct size hole then screw the blots straight into the wall. I use them in work to secure large floodlights and they are a good job.
  5. karl7900
    1,392
  6. karl7900
    1,392
    Best bet are the ones with a bolt head then you can use a ratchet to tighten it up.
  7. abdus
    abdus Top Gear VCDS Map User
    1,827
    IMO they heat up, that's why they are breaking. Get better screws as karl7900 advised.
  8. Randomjim
    2,752
    I got shorter screws in the end and they did the trick. Hopefully it won't fall down lol.
  9. fingermouse
    fingermouse thats me
    4,003
    112
    Fisher fixings work quite well, Id be tempted to no nail it to the wall as well as screwing/bolting it , think it will take some hammer lol
  10. DriveByShooters
    DriveByShooters Editor Audi-Sport.Net Magazine
    1,189
    Could use it as a kick bag if it does! :haha:
  11. Randomjim
    2,752
    Ha ha yea might have to, not going through all that aggro again lol.
