DIY help. Stripping old paint from Plastered walls?
Westy Jul 17, 2012
  1. Westy
    Westy Well-Known Member
    17,443
    1,103
    Hi guys I need some DIY help if possible.
    I've just moved into a 30 year old house and me and the GF have started to strip the walls down to redecorate. Underneath 2 layers of wallpaper and a layer of lining paper we have got down to the original plastered walls that have a light coating of emulsion. We want to wallpaper 1 wall per room and paint the rest so want to get right back to the plaster before repainting.
    My old man has done a fair bit of decorating in his time and he recommended we get all the paint off before repainting as any water based paint will just make the old emulsion bubble and flake. I've started scraping the wall with a wallpaper scraper and I am getting through it but it's taking such a long time. Here's a pic:
    I'm sure there must be an easier, faster way to do this?
    Does anyone know whether there is a specific type of paint stripper that can be used on plastered walls?
  2. hades-
    9,481
    646
    if its emuslion then use a steamer
    it melts it and when it drys a bit u can scrape it off easy or it pulls off like rubber when its warm
    its a fukker to do tho
  3. Westy
    17,443
    1,103
    Bummer.
    Been searching the net for some sort of special paint stripper for plastered walls but it doesn't seem to exist :(
  4. hades-
    9,481
    646
    iv just had to do the same and couldnt find anything.
    but with the steamer it peels off
  5. Westy
    17,443
    1,103
    I'll give that a go then, thanks.
    Any steamer you'd recommend?
  6. sportstractor
    sportstractor Chugger
    2,709
  7. hades-
    9,481
    646
    i used the B&Q one
    was about £30
    just avoid scrapeing it dry and ****ing the plaster up.
  8. Westy
    17,443
    1,103
  9. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    767
    If you don't mind the dust use a belt sander, but mask up well as plaster dust is now hazard classed the same as asbestos dust.
  10. StateOfPlay
    StateOfPlay Well-Known Member
    2,257
    191
    Lining paper I reckon.
  11. lgooch
    lgooch Well-Known Member VCDS Map User
    1,114
    145
    Chances are after that scraping the finish of the plaster would not be good enough to simply paint.
    Why not just leave it and get it skimmed. Then you would a fresh glass like finish for some fresh paint. Beats the hell out of scraping, filling and then sanding it all over with a less superior finish.
  12. Westy
    17,443
    1,103
    Well I got some plaster friendly paint stripper from wickes and it's definitely speeding things up. You can see the darker patch is the bit I've done with paint stripper as you have to brush down the wall with water afterwards.
  13. adamss24
    adamss24 Well-Known Member
    4,578
    402
    Skim over then paint in the shade you like, by using nitromors you might have an adverse reaction when it comes to paint. Either fresh plaster or lining paper...
  14. _G_
    _G_ Active Member
    876
    Nitromors works but it is painful to use... you have to leave it on longer than the pot says for the best result.. and you are looking at a good amount of drying time as the plaster is porous and it needs to dry out before you put your basecoat on (be very careful not to scrape it off too hard as it can loosen damaged plaster).. a good base coat like the polycell 3 in 1 would do a fine job once its dried... alternatively you can use this:
    Polycell SmoothOver Your Textured Wallpaper
    Yeh you don't have wallpaper but you may have the slight raised surface where the existing paint is.. if thats not the case then this will do the job/can be used once you have removed the old paint:
    Polycell 3 in 1 Basecoat
  15. fingermouse
    fingermouse thats me
    3,996
    111
    I`d get the walls skimmed
  16. dandi78
    dandi78 New Member
  17. Gazwould
    Gazwould Well-Known Member
    4,788
    1,927
    DieselJake likes this.
