DIY heat shield - for under £20
Piester Feb 23, 2011
  1. s30000t
    s30000t Member
    67
    what size are your jetex filters lads ive looked on the jetex site and theres about 10 different options for the 75mm neck
  2. Westy
    Westy Well-Known Member
    17,443
    1,104
    Most are using the FR-08001 which has an 80mm neck.
  3. s30000t
    s30000t Member
    67
    thx pal but i thought that the maf is 76mm???
  4. Westy
    17,443
    1,104
    **** knows, all i know is everyone is running that model
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    80mm- s3
    75mm- a3
  6. s30000t
    s30000t Member
    67
    cheers lads and do you recon if i took the gorse out of each side of the maf or custom built a larger less restrictive housing for the sensor it would help?
  7. Westy
    17,443
    1,104
    A few people have done tests with de-meshed mafs and it didn't produce much in the way of results. Some say that the mesh is there to ensure that the airflow across the sensor is stable.
  8. s3dave
    10,110
    736
    You cant make a bigger housing as the calibration/readings will not be correct...why would you want to do this? the maf does not max out on normal + s1+s2
  9. s30000t
    s30000t Member
    67
    yeah that makes sense but what about a larger housing surely that would help might fabricate 1
  10. Sam_
    Sam_ Down under
    3,038
    480
    Don't waste your time!
  11. s30000t
    s30000t Member
    67
    yeah looked into it bit of a waste of time oh well least i looked into it 1st instead of me goin crazy with the dremel lol just finding my feet with this engine and exploring all the possibility's dont suppose you guys know what the 4 connections are on the b5 tip?
  12. s3dave
    10,110
    736
    The same thats on the standard tip...
  13. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Just a quicky....
    I went to B&Q, Homebase and Wickes none of which sell sheets of steel/metal.
    Where has everyone been getting theirs?
  14. Dani_B19
    9,320
    389
    Dave, he's now audi-sporta local deala :) haha.
  15. J B
    J B Member
    140
  16. S3 TAM
    624
    10
    thanks guys. i just bought a bit off ebay 100cm x 100cm x 0.9mm
    hopefully i'll be able to bend it.
  17. S3 TAM
    624
    10
    Found Some Steel in B&Q in the end.
    So I was a busy boy yesterday and created this it's not as good as some of the others I've seen but it does the job and i'm quiet happy with the results.
  18. Westy
    17,443
    1,104
    That looks like a pukka job mate. Start nocking them up and selling them ;)
  19. S3 TAM
    624
    10
    it took me about 7 hours start to finish. It was a pain in the Ar*e but worth it.
    I used the net diagram in the first post but added length to it, to protect it more from the heat.
  20. S3Lol
    S3Lol Member
    422
    hmmmm, heat shield to be done next weekend by the looks of things. Being single again is definitely helping the car out :)
  21. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    That looks awesome! Wish I had the skill to do this...
  22. Westy
    17,443
    1,104
    Knowing S3 Baby there wasn't much skill involved ;)
    You just need some patience and the right tools, dont be put off having a go at one.
  23. S3 TAM
    624
    10
    Very true dude. Patience is needed i nearly chucked it in the bin half way through.
  24. Dani_B19
    9,320
    389
    Is 0.5mm aluminium ok to use for this? Not to thick or too thin is it?
  25. Westy
    17,443
    1,104
    Yeah that'll be fine. S3 baby used 0.6 for his
  26. Dani_B19
    9,320
    389
    Sweet.
  27. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,208
    2,028
    I don't wish to sound negative but would it not be better just straight to the battery on that side ?
  28. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    187
    Just wondering, can you still gain access to empty your catch tank now
  29. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,267
    360
    has anybody thought of taking the little rubber bushings from the standard airbox and using them to try and reduce/damp the vibrations that are transmitted to the MAF?
  30. s3dave
    10,110
    736
    you have to buy the material....spend hours on it ....when theres a guy selling them on ebay for £20 oddish quid...:whistle2:
    mention... Audisport and i believe he gives them away @£20...
    S3Lol likes this.
  31. rhubarb4
    1,754
    187
    Oh any more info :blink:
  32. Westy
    17,443
    1,104
  33. Speedy Steve
    Speedy Steve Active Member
    1,258
    Dam why didnt i know this before i bought mine
  34. badger5
    9,505
    2,003
    s3dave..
    you sure this fits? without bending it I mean.
    a customer brought me one, which looks pretty darned similar ;) and it did not fit well at all.
  35. s3dave
    10,110
    736
    Pm,d, yes they fit..:thumbsup:
  36. Sam_
    Sam_ Down under
    3,038
    480
    Dave, can you send one to me in Sydney?
  37. s3dave
    10,110
    736
    Its not worth sending @£55..:ohmy: you may as well make your own, sorry sam
  38. badger5
    9,505
    2,003
    must have been someone else's attempt... close but no cigar for that one
  39. Sam_
    Sam_ Down under
    3,038
    480
    Damn. I guess you, like Bill, don't use Royal Mail at that price. Fair play :)
    Shame, the AUD is doing quite well so I've been buying a bit of gear from back there rather than the states.
  40. S3Lol
    S3Lol Member
    422
    Ive just sent you an order Dave. Make it good otherwise there will be trouble ;)
