diy fitting of new lowering springs 19tdi se
stephen lab Sep 6, 2009
  1. stephen lab
    stephen lab New Member
    planning to fit the springs next weekend, just wondering if its pretty much straight forward and any specialist tools needed or not. any advice welcome..also fitting rs4 arb but that looks easy ish..
  2. Dazmo
    Dazmo Active Member
    1,762
    What springs you getting mate and where from?
    How much you lowering it by? im thinking of doing this myself but dont want to go lower than 30mm.
  3. Broken Byzan
    13,237
    465
    You will need spring compressors, a deep swan necked spanner 21mm IIRC and a good solid jack and stands. Over and above standard half inch drive sockets etc
  4. Dazmo
    Dazmo Active Member
    1,762
  5. paul20v
    paul20v Audi fanatic
    1,113
    Start soaking the front pinch bolts and buy some new ones .
  6. stephen lab
    im fitting eibach springs 40mm rear 50mm front and i got them from dpm, they advertise on the forum. what part is the swan neck spanner for?:uhm:
  7. stephen lab
    they cost me about 135+ 10 del.
  8. stephen lab
    whats the swan neck spanner for?
  9. Broken Byzan
    13,237
    465
    The damper top nuts, they are sunk down quite a bit and you need to be able to get an allen key through the centre to hold the damper piston still.
  10. stephen lab
    we thought we could of done it without taking the rear damper off , i guess we were wrong?
  11. Broken Byzan
    13,237
    465
    For the front ones mate
  12. Dazmo
    Dazmo Active Member
    1,762
    anyone got any pics of a b7 audi a4 on 30mm eibach springs?
    Just want an idea of how low they will look?
  13. stephen lab
    a suppose we,ll find out at the weekend, cheers any how
  14. stephen lab
    so do you take the rear damper off from the top or bottom, sorry for keep asking but id rather know now, just so it go,s smoothly at the weekend.
  15. Broken Byzan
    13,237
    465
  16. stephen lab
    looks like we,ll b able 2 manage it. cheers..
