DIY debadging - easy to do?
razza1 Jan 10, 2009
  1. razza1
    razza1 Well-Known Member
    3,048
    803
    I'm thinking about debadging my A4, is this an easy job, or is it best left to the proffesionals? I don't want to damage the paint work...
  2. jcs356
    jcs356 Brum brum
    2,723
    64
    Easy - you need some strong thread or dental floss and carefully cut behind the badge with it. You'll then need something to get the glue residue off, and depending what colour your car is and how old, you may need to gently t-cut/colour restore to avoid having a shadow left on the car.
  3. razza1
    3,048
    803
    It's Phantom black and only a couple of years old, so shouldn't be any paint fade, hopefully won't have to be a t-cut job then.
    What's best to get the glue residue off with?
  4. jcs356
    jcs356 Brum brum
    2,723
    64
    I can't remember what I used on mine - I think it was either WD40 or Autoglym bug & tar remover
  5. eagle_s3
    eagle_s3 Member
    81
    Another way you might want to try is to use hot water, I did this on mine.
    After washing the car I poured one or two kettles worth of hot water over the badges at the back, then using just my nails got in behind the badge and started to peal it back, the edges come away easy enough. You'll get so far and then need some more hot water. then just repeat the process using more hot water when you feel that the sticker is still holding firm. It sorts out the glue and the badges come away without leveling a - any scratches and b - not very much of the sticker is left behind. for the stuff that is left Autoglym tar and bug remover is the ticket. Dab a good amount on, let it work for a bit then start to rub it off.
    I felt this was a better option and the dental floss and i'd used it perviously on my Golf Gti.
    Best advice for either method that you end up using is take your time.
  6. tja
    tja Member
    Found that hot air gun and credit card works to remove badge, and neat petrol on a cloth will remove residue.
  7. graham A4
    graham A4 A4
    17
    jusdt use a a plastic card something more sturdyer than a cr card and take your time, the badges will come off with ease ive seen it done many times, they are only adhesive so it will not affect ur paintwork although there will be a colour mismatch
  8. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    I would say use a hot air gun or WD40 to remove the sticky.
    To remove the badge, use fishing line in a sawing motion, don't use any tools/cards etc as a slip can cause a scratch, I did mine with fingers only.
  9. audi80sport
    audi80sport is it home time yet?
    116
