DIY Air con re gas / top up
Ian2012 Jul 24, 2013
  1. Ian2012
    Ian2012 Active Member
    473
    29
    Just out of interest has anyone ever tried using one of these cans i keep seeing in Halfords? Are they any good do they work?
  2. Point_Audi
    Point_Audi Vorsprung durch Technik Staff Member Moderator VCDS Map User Gold Supporter Team Tornado Audi A5 Black Edition S-line owners group
    1,377
    949
  3. glenandem
    glenandem Active Member
    674
    31
    Hi pal, I've never tried one but from my days if working in a garage and using ac machines, I imagine these DIY ac are just for topping the lost gasses over time u lose, i don't know how much they cost but I think you'd be better taking it to a garage or a mobile ac man for a full ac regas with a good vacuum to suck any moisture that might have built up over time!Our garage used to sell regases on the idea of bacteria that breeds in ac systems apparently it does with the cold conditions etc.
    I once vacuum'ed my own car for an hour and half and the system was just above freezing having a nice patch on the windscreen!
    Wish I had access to an ac machine now my a4 needs a regas when I've replaced the g65!
  4. Robclat
    Robclat New Member
    Hey, did this at halfords last week.
    Like having a new air con system!
    Cost £35 and still have half a canister I can use next year. Obviously only any good if it is a re gas not compressor issue.
  5. madmike01uk
    madmike01uk Member
    430
    21
    does this add oil to the system? You can get a full proper regas for around £30 so seems a bit pointless to me.
  6. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    I was told to stay away from these DIY kits as they contain chemicals that may degrade / damage the air-con system over time.
  7. deano1978
    deano1978 different gear
    713
    80
    Also if theres a problem its wasted money and gas. Kwik fit (did) ? have policy with the ac ,if thers no change in temp then no charge.
    Ive been there twice,1st no change in cool air,no charge.
    2nd time changed pressure sensor,still no temp change=no charge.
    Thinks its new compressor time :-(
