Diverter valves - which way
adidasandy Feb 25, 2012
  1. adidasandy
    adidasandy Member
    271
    Ok, might be a silly question but does it matter which way the diverter valves go? the reason why I ask is after doing to research on the net I have seen them both up / down and on there side. Had a look at mine and 1 if facing up and 1 on the side, does this cause any issues?
    Andy
  2. aragorn
    18,606
    871
    The OEM valves should be mounted with the boost going in the side of them, and the intake pipe going to the bottom port.
    On an S4 this means they're on their side, with the vacuum nipples pointing towards each other.
    However various aftermarket valves are supposed to be installed the other way round.
  3. adidasandy
    adidasandy Member
    271
    Ok so with mine being 1 one way and 1 the other is not right, right? I have Forge 007's so which way should these be fitted?
    Andy
