Diverter Valve q's
madvw Aug 15, 2006
  1. madvw
    madvw Active Member
    2,489
    hopefully someone can help me out here...
    After 36k on the original DV, its about (over) time to change it. Im not noticing huge performance problems, but it does feel a little laggy, and I can hear the turbo hiss much more than on my brothers TT.
    The questions are:
    1. I still have the factory crimp connectors on, I know that these are not reusable, but what are the sizes i need for the vac, boost in, and boost out pipes? Yes i know i'm lazy not to just measure them...
    2. Some people replace the vac hose when replacing the DV. Is this really neccessary?
    Cheers. :beerchug:
  2. Olly_K
    Olly_K Administrator
    2,678
    I believe the crimp connectors are re-usable, you just need the special tool to release them. I just used jubilee clamps on the wifes A3.
    cant answer number 2 for you :(
  3. dummi
    dummi smoking a6
    1,210
    1. measure them you lazy get :D
    2. you only need to replace them if they are worn.
  4. madvw
    madvw Active Member
    2,489
    haha, unless I can find a VAG crimp tool, I'm gonna have to get off my **** then! :lazy:
  5. dummi
    dummi smoking a6
    1,210
    once the vag's are off don't bother with them, jubilees do nicely, get smallest for the vacs, dv's are around 30mm
  6. madvw
    madvw Active Member
    2,489
    nice one, thanks!
  7. JamS3
    JamS3 Active Member
    2,258
    23
    Just like madvw I have noticed a slight drop in performance recently.
    My car has not been pulling as it has been and it seems you need to really press down on the accelerator to get any performance instead of just part throttle.
    I have changed the DV back to the original one from a Hyperboost one and the difference was amazing, I get a more noticable boost noise from the DV instead of a weak wooshh that I used to get and car pulls better on part throttle.
    Do these DV's ie the Hyperboost ones weaken over time?
    Just that on my previous S3 this DV was sticking, it was supposedly serviced and good for use again but seems to have broken again? The spring seems softer when pressed than the original Audi OE one, would this make me lose boost if it takes little pressure to lift the piston?
    For info the Hyperboost one has probs done around 45k on the original spring and seals etc...only being cleaned and lubed up with oil.
    Any comments would be appreciated!
  8. Quattro_Lew
    Quattro_Lew All Torque
    206
    in and out tubes are 30mm and i just re-used the vac one, job done :)
  9. mattyboy199
    mattyboy199 Well-Known Member
    1,889
    29
    can anyone show me where the DV is located ?
  10. TRS1
    TRS1 Topper Harley
    328
    I used jubilee clips, much easier even though if you have the tool you can re-use the clip ones. Vac hose doesn't "need" a clip as it is sucking so only put one on if you'll worry about it!
    P.S. take the engine cover off and the DV is behind the head and slightly to the right. Follow the hose from the airbox to the inlet and you won't miss it! :thumbsup:
  11. dultanur
    dultanur all promises, no action :)
    407
    jamS3, maybe your DV needs a rebuild? piston type DVs leak air as the grease gets pushed away...won't seal properly. but i don't know how often they will need a rebuild.
  12. superkarl
    superkarl MAN OF STEEL
    9,569
    2,464
    can someone confirm this?
  13. mattyboy199
    1,889
    29
    yes this is correct however the jubilee will need to be larger.
  14. superkarl
    9,569
    2,464
    I think I may have confused myself and you.
    Inlet and outlet of DV. Not the 'tubes' which the op refers to, I.e. External diameter of pipes.
    I need the internal diameter.
  15. david7m
    david7m Active Member
    551
    44
    Im on 138k and it was only changed about 30k under warranty.
    Should I replace mine? Haven't noticed any problems though.
    Dave
  16. mattyboy199
    1,889
    29
    internal diameter must be about 25mm.
    Dave no harm in changing it, buy a forge or bailey item. I would also check for boost leaks.
  17. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    The DV inlet and outlets are 25mm.
    Epic thread bump Karl.
    /thread.
  18. david7m
    551
    44
    I'm too old for a psst between changes 😊
    How do I check for leaks?
    Dave
  19. superkarl
    9,569
    2,464
    Thanks jardo
