Disk changer
Taroni Jan 30, 2011
  1. Taroni
    Taroni Member
    My disk changer will not play copyed disk its still the oem one is there a newer version of the disk changer thats just plug and play that i can put in or is there any other way ?
    its 98 model
    and i mean normal audio cds not mp3s
    thks
  2. Watty
    Watty ..... (_!_) Sarah's A3s #1 Fan
    404
    Just make sure when you rip the cd that the files are saved in the correct format so can be read by the cd player/ changer. Check and have a play around, can't remember if they should be .wma or something similar, see what file extension the originals are? Try and google it, by mine is ok (2002). Try it in the front/ dash too.
  3. Allroader
    Allroader Audi 3.0 V6 TDIs every time
    101
    In burn options, make sure you haven't set it to burn without gaps between the tracks. (and you've selected audio CD not data - just checking)
  4. TwistedMind
    TwistedMind Long Live The A6
    115
    Mine works fine, like the others are saying make sure you have not riped the tracks in MP3 format.
    There is a web site that supplies a converter that changes your CD changer into a MP3 socket for flash drives
  5. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    Mine is also a 98 changer and it reads copy disks with no spaces fine.
    Just make sure you are burning correctly.
  6. Taroni
    Taroni Member
    i used nero9 instead of media player and it works fine now ,thks all
