  1. Hotscar
    Hotscar Four Wheel Drifting
    562
    Not an easy question to answer I'm sure (motorway and town miles considered) but when roughly should I replace brake discs? They do have an edge to them, my car has covered 54k and has had a mixture of town and motorway driving. Also, can I just replace my current discs with black diamond or do I have to change the callipers?
  2. S3_MCD
    S3_MCD Member
    389
    I did 40K on OE disc and pads b4 upgrading to Combi discs and pads (see signature).
    Discs still had life in them when I took them off...
    BDs are much better - no fade whatsoever.
    Straight swaps with OE items, had to rewire the pad wear indicator (2min job). Calliers will be fine.
  3. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    I'm up to 46k on my original disks. My car is mainly for the weekends and gets driven hard. I've been through a few sets of pads, but the disks are only just coming to the end of their life.
  4. Ess_Three
    Ess_Three Active Member
    5,383
    [ QUOTE ]
    [/ QUOTE ]
    Hell! My first set of standard discs lasted under 10000 miles...they were destroyed!
  5. ChriS3
    2,239
    27
    Evil Man! Ever heard of mechanical sympathy? heh, OK I drive hard, but not as hard as some.
  6. Khufu
    Khufu Well-Known Member
    5,704
    31
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    I hope some of them were track miles or an attempt to give cause to upgrade them /ubbthreads/images/graemlins/goofy.gif
  7. Ess_Three
    5,383
    [ QUOTE ]
    [/ QUOTE ]
    Road miles only I'm afraid...
  8. god_thats_quick
    2,507
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Just out of curiosity, how long did tyres last? - I'm guessing not long at all!
  9. Ess_Three
    5,383
    8-10,000 miles a set...rotating them.
    And running aggressive suspension angles with lots of negative camber.
  10. imported_gek
    imported_gek Guest
    I'm on 47k with original disks AND pads!
  11. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    [ QUOTE ]
    [/ QUOTE ]
    Do you use your brakes at all?
  12. HTC
    HTC Active Member
    3,428
    9
    Hotscar, you replace discs if they become thinner than the factory stated width, become cracked, damaged or warped.
    If you have no braking wobbles or issues and they are withing width tollerances you don't need to replace them.
    I can check the minimum spec if you like?
  13. Hotscar
    562
    Ok, thanks for your help. There doesn't seem to be any problems and at my last service they didn't mention anything on the 'advisory sheet'. If I'm going to be honest, I'm just thinking ahead for when I do need to replace them and what to put on. I'm not into lots of modifications (if any) but if I can get some better discs (standard have faded on me a few times) without having to put different calliper etc on when they're due, then I probably will.
    Thanks for ya help guys...interesting reading and I can't believe someone can go through discs in 10k...
  14. HTC
    HTC Active Member
    3,428
    9
    I'm sure you provided Mr. Ess_Three with a sporty motor a free access to a track he could kill a set in a weekend! /ubbthreads/images/graemlins/grin.gif
