Discovered a buckled alloy wheel
MrLapou Apr 16, 2012
  1. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Since buying the car few weeks back, had it on the Motorway at the weekend.
    Felt a slight steering wheel shake around 70mph, otherwise it's silky smooth.
    Decided to take into local tyre shop. Chap called me over to show the wheel spinning on machine and the buckling it has..
    Said it's quite common occurrence these days to see inner edges of near side fronts to suffer this.
    In two minds to have this seven double spoke 18"er fixed, replaced with new/used or leave it, but swap to rear.
    Your comments suggestions welcome.
  2. andy1acars
    andy1acars Member
    112
    14
    Some can be repaired, better if put on rear, try www.alloywheelsdirect.net pricey but good service and genuine, i bought an original AMG rim off them with a rare offset. Or buy another of ebay and make sure it has Audi logo and Ronal stamped in rear of rim.
  3. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
    if you do alot of motorway millage then replace the wheel, if your doin local driving then you can get it sorted and stick it on the rear.
  4. audigex
    audigex Active Member
    600
    46
    If it's just a comfort issue, I'd go with amar06fbr. If there's any question of safety, replace it. Your wheels are the only thing keeping you on the road, and are not to be trifled with.
  5. MrLapou
    1,233
    121
    All sorted... bought a used wheel with 6mm Potenza tyre for £115.
