Disconnecting Bose
ST09 Mar 17, 2010
  1. lgooch
    lgooch Well-Known Member VCDS Map User
    1,114
    145
    Mine is a MY12 car and the pin has been moved correctly and coded and i didnt need any adapter cables No GALA settings on the RNSe so it all works as it should. Just sounds shoot !
    I will report back on Friday as I am currently away with work
  2. Ben England
    Ben England New Member
    Hiya, I know your pain. I have just picked up a brand new s3 with Bose and sat nav and it is awful. I can not believe how bad it sounds. I am tempted to try this wire trick but I am not sure it is valid for the new units?
  3. lgooch
    1,114
    145
    Ben. Try it. It has improved mine
  4. audicruiser
    audicruiser Audi Heaven
    1,865
    Take it back under warranty on a new car!
  5. audicruiser
    1,865
    Has yours been coded for the Bose system? The code for RNS-e should start 209****
    If it starts 205**** then this will be your problem...
  6. lgooch
    1,114
    145
    Yes
    All coded correctly and sounded gash
    Whipped the Bose wire out and all of a sudden I have more Bass where as before it sounded very flat. After this it did not make a difference whether the wire was in or not. So left it out.
