Disconnected EGR Pipe now Warning light
Caesium Mar 10, 2007
  1. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    I disconnected my EGR vacuum pipe from the EGR valve to try and stop it from opening and filling my intake manifold with soot and ****, but now I have got a warning light on my dash, any idea why anyone?
  2. vw754
    vw754 vorsprung Durch Technik
    2,331
    58
    SIMPLE! reconnect the egr it will go off!
  3. Caesium
    4,879
    but i don't want the EGR to keep puffing soot into my intake manifold, can I just VAG-COM the light off?
  4. Diesel Dan
    Diesel Dan New Member
    I have had the same problem when I blanked off the EGR valve with a metal plate. A fault code was stored stating EGR valve was outside limits.
    On clearing the fault code and removing my blanking plate, Fault code has not returned. I would also like to stop the inlet manifold from getting chocked up with carbon.
    The Mass Air Flow meter must be able to detect the difference when the EGR valve is not in use.
    If anyone has an answer about how to disable the EGR please let us know.
    My engine is 1.9 TDI 130 bhp AVF
  5. S3Andy
    S3Andy Member
    265
    Give Allards a call on 01452 500333 have a chat with Lloyd and he maybe able to help ;)
    P.s my Ibiza always had the CEL light on the dash when I fitted the EGR replacement kit 451452 5003332 500333
  6. james0808
    james0808 Active Member
    3,548
    I was lucky with mine,never had a cel light.Mine is AWX,what engine code do you have?
  7. inigoj
    inigoj Member
    263
    I never had any problems when i disconnected the pipe on my EGR.
    Have you made sure the hose from the 'n75' type valve is properly sealed?
    Is your EGR closing properly?
    You can VAG-COM the EGR to vastly reduce its operation, or stop it.
    I ended up reconnecting mine on my 'afn' engine, when i was trying to diagnose a boost problem.
  8. fjtwelve
    fjtwelve Moderator Staff Member Moderator
    770
    10
    Try tdiclub.com, there are plenty of guys on there who have disconnected their EGRs
  9. Seraph
    Seraph New Member
    nope, the egr is connected directly to the ecu
    use vagcom to address the issue.
  10. Jason
    Jason Member
    188
    I cleaned and disconected mine on a 1998 V6 tdi,it ran a treat for years with no warning lights etc.............
  11. Mcgough
    Mcgough Member
    846
    SOOT..... VALVES >>>>> N75.........
    ...IM LOST NOW........???
  12. Jason
    Jason Member
    188
    GPS?
  13. Rev-head
    Rev-head Active Member
    2,987
    LOL!!
