Disable ECU via VAGCOM
S3 TAM Sep 10, 2010
  1. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Hi,
    Just wondering if you can do this. so you can't start the car even with the key.
    Just think about when i go away i can disable the car completely.
  2. thegoal007
    thegoal007 Another S3 owner....
    805
    26
    Even if you could do this with VGACOM I would be in fear of not being able to bring it back to life !
  3. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    I take it you don't have a Revo remap then mate?
  4. S3 TAM
    624
    10
    No I don't I think I need one.
  5. s3 Hoggy
    1,716
    158
    What about if u were to pop the coilpacks out? 5min job?
  6. gavin89
    gavin89 Wana go Low gotta go Slow
    214
    Disabling the ECU is a bit extreme? South East London is that bad eh lol
    You can take the battery out :p
  7. sportstractor
    sportstractor Chugger
    2,709
    haha that is nuts. Cant you rent a rotweiler to guard it for you
    maybe pull out fuel pump relay? Although some of these criminals are cleverer than we think.
  8. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    my APR software disables the ecu...but like said its a bit extreme to disable it ...there are plenty of things to do to immobilise it...pull the fuel pump fuse...
  9. aham_uk
    aham_uk Member
    32
    If you have the SKC, you can tell the immobilser that there is no keys for the car (via instruments 17).
    No matter if you leave the key in the car, it wont work.
  10. jojo
    28,998
    3,652
    How do you restart it afterwoods? Since you need the ignition to be live for Vagcom to work, or does that part of the car stays active?
    I'd just jack the car up, remove 2 wheels and put some bricks under, then it won't be going anywhere! lol
  11. gavin89
    214
    No you dont need keys in the ignition to scan and operate module 17 instruments, it is set to be always active.
  12. jojo
    28,998
    3,652
    Cool.
  13. Lemon S3
    Lemon S3 Alex
    1,390
    41
    What about using a kill switch?
  14. gavin89
    214
    Maybe you need one of those kits...:rock:
  15. sportstractor
    2,709
    the simplist answer is to park it somewhere secure.
  16. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Take the Forge DV off. If i was a thief and stole an S3 in limp mode i'd be pi$$ed :laugh:
  17. JDover
    JDover Member
    57
    lol, on top of the battery on that little bar with the electrical connections on is the main live for the fuel pump.. take the 10mm bolt off and put a rubber washer underneath. don't ask how i know but it works a treat :)
  18. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    is it an AGU? if so u could unplug the ignition amplifier then it wont start at all
  19. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Was playing with Vagcom earlier n saw a 'transport mode'. Does this turn the shock sensors off on the alarm or does it make the car undriveable?
  20. NHN
    29,577
    1,779
    You know these were real aswell in South Africa, aswell as a briefcase with the same feature cause of so much carjacking.
    The plate shows for Gauteng Province which includes Joburg, where it was rife.
