Disable Audi A4 Avant alarm (boot sensor is reporting open boot & setting off alarm)
marballs Feb 2, 2013
  1. marballs
    marballs Member
    54
    Hi
    My Audi A4 Avant has developed a problem. At first it was just that it would report to me that the boot is open when it is not open.
    I could live with this, however yesterday evening the alarm was going off keeping the neighboursup. Not a good way to be popular where you live.
    So I need to get it fixed urgently.
    Question:
    1. Is there a way of disabling the alarm for sure. The Manual says:
    "If the vehicle has been unlocked withthe key at the drivers' door the key must be inserted in the ignition lock andthe ignition switch on within 15 seconds of opening the door in order to switchoff the alarm. The alarm will be set off if the ignition is not switched on within15 seconds."
    And it uses bold in the manual where I have done. However I don't understanding this statement asit seems to contradict itself and generally I'm just not sure even when I try it if the alarm is off. Also googling it seems to give contradictory information.
    2. Is it going to be easy to fix the actual problem if the boot sensor thinking the boot is open
    Also about a fewdays before this fault I should also add that my rear windscreen wiper goes offrandomly and does not reset in the proper reset position. It will just stophalfway through.
    In Sept 2012 (about 5 months ago) Audi did repair the rear washer pipe as the rear jet did notwork. Maybe other damage has occurred as a result.
    I welcome any input on this. Thanks
  2. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    enter the car via passenger door, leave door open, push lock button on drivers door, exit passenger door, shut passenger door
    = car locked, alarm off
    using any fob or key to lock the car will arm the alarm
  3. marballs
    marballs Member
    54
    OK I'll try that.
    Anyone know how I could fix the boot sensor easily?
    I have a AA warranty. Would not buy again but I have to pay £50 diagnostic and if approved by insurance the garage should do the work so I think I'm going to go down this route. Annoying I have to pay the diagnostic however.
  4. marballs
    marballs Member
    54
    Sadly this does not work for me. Therefore when I sit in the passenger seat and try and press the lock door button on the driver side, it does not react when I have the passenger door open.
    If I close it anyway, all the other doors are locked by the passenger door remains open (so I guess you really can't lock your keys in the car).
    Also if I try with the passenger door close, press the lock button, and then leave from the passenger door, same result. all other doors are locked by the passenger one remains open.
    I'm hoping slamming the boot down hard will at least buy me time until I can get to the garage. however if tonight my neighbours burm me or my car, then we know it did not work!
  5. kite
    kite Member VCDS Map User
    677
    Sounds like you have a leak in your rear washer and the water has affected the wiper motor and the tailgate lock.
    Its quite a common fault.
  6. marballs
    marballs Member
    54
    Darn it. You know that I had no problems leaving my rear washer broken for 3 years. I just never used it. In sept 2012 I had it fixed by Audi, and now I have new problems. Should have left it!
  7. marballs
    marballs Member
    54
    Do you reckon I go ahead with my private garage fix, or take it to Audi and moan at them hoping they will sort it for free / good price?
  8. kite
    677
    Im only guessing thats your problem.
    Would need to strip the tailgate out to confirm.
    Go to whichever garage you trust.
  9. Paul B7
    Paul B7 Active Member
    622
    34
    Audi don't do ANYTHING for free....................
  10. Evans94
    Evans94 Guest
    Hi
    I had this problem yesterday which led to my roof not opening - it kep saying boot was open and it was not.
    I sprayed WD40 inside the locking mechanism last night and whilst it did nothing last night and idrove it this morning and the warning message had gone! Just remember to open boot again as the alarm needs to re-set it self.
    Mine is a 57 plate convertible and not sure if it is the same as yours but it might be worth a try. - Good luck
    BR
  11. marballs
    marballs Member
    54
    going back a while here, but I have the read lock for the bot replaced (cost me £50 excess using my warranty on a Halfords garage) and problem was solved
    I never use my rear washer so water is never pumped to that area
