DIS warnings
Matt Mar 31, 2008
  1. Matt
    Matt Active Member
    1,404
    When I have the car started and press and hold the button to the left of the DIS it flicks through all the possible warning symbols.
    Is this some kind of test feature?
  2. redbutcher
    redbutcher Member
    649
    Funny you saying that - I did that today as well while changing the clock - yep, it's a test function - a bit like the check option in the DIS menu, but this does all of them in one hit.
  3. r1ck123
    r1ck123 Member
    34
    Yes it is a tester button,
    but if you do have a fault press and hold and it will give you a message on the course of action to take
    ie if the oil warning symbol appears press and hold and you get SWITCH OFF ENGINE AND CHECK OIL!
  4. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
    Did exactly the same yesterday.
  5. consilio
    consilio Up the owls!
    666
    Did same today.
    Doea anyone know how to enable the 'time from radio signal' feature that is mentioned around page 11 of the manual?
  6. mitch78
    mitch78 Active Member
    2,350
    :thumbsup:
  7. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
    Perhaps you will excuse the stupid question, but doesn't it tell you in the manual?
  8. h5djr
    9,463
    1,770
    Nothing on page 11 in my Sportback manual but I assume it's in connection with the Radio-controlled clock which is not fitted to UK models.
  9. consilio
    666
    hehe, thought someone might pick up on that. I had a good look round and couldn't find anything about enabling it, only that its there and shown by a little ariel mast on your dash display.
    This was in the S3 manual
