DIS warning symbol..Engine oil sensor faulty
M4KTT Jun 5, 2009
  1. M4KTT
    M4KTT Member
    96
    I've been getting this faulty oil sensor warning in my DIS. its only coming on intermittently, but I want to change the sensor..how easy a job is it? and where is it?
    its definately the sensor one and not the level one btw.
    cheers.
    Mark.
  2. auroan
    auroan Active Member
    1,669
    When did dis start telling when sensors were fautly ? You sure it's not oil pressure warning
  3. M4KTT
    M4KTT Member
    96
    its the same symbol as this except it says 'SENSOR' instead of 'MIN'.
    manual says to take to dealer(no chance!) and have the oil level sensor checked.
    oil levels are fine. and the oil is getting to the top end as i have a weep from my rocker gasket!
    http://blogs.edmunds.com/roadtests/555 low oil lamp.jpg
  4. evilscotsman
    evilscotsman Space Cowboy
    1,350
    14
    mine did the same, started 3 weeks ago....the engine blew up on monday. Seized cam, seized turbo, clogged oil pump.
    Read my post on oil pressure / level warning......once the warning stays on, the pin is out of the grenade - as j7uss put it. They warned me not to use the car after the warning stayed solid, I did, and it went bang the next morning.
  5. M4KTT
    M4KTT Member
    96
    Not again! I've already replaced the turbo once before...I got low pressure warning last time...
    Its had castrol edge oil too...and i've not done many miles.....
    its going in to volksmania in the wirral on monday.
  6. evilscotsman
    1,350
    14
    good plan mate, hope its ok. Did you have to replace the head / valves or cam timing unit last time? This has happened twice to mine as well but I caught it before the damage happened, then the oil was fully synth, extra large filter fitted etc, and it did 6k then started the oil pressure thing again, third time I did the oil & filter it only lasted 3 weeks and about 900 miles before going pop...
  7. golf
    golf ***** rent boy VCDS Map User
    1,556
    Oil sensor is different to oil pressure.
    My oil sensor went, and I got the warning of "Oil Sensor" on the DIS. Got a new one from the scrappers and the warning disappeared. It's a very easy job to do, the sensor sits at the bottom of the oil sump and is held in with three screws and some kind of gasket/cover, all the oil comes pouring it when you change the sensor though, so keep a pan handy.
  8. M4KTT
    M4KTT Member
    96
    My pick up blocked on the way to cornwall back when gloucester flooded (07?) so it did the turbo bearings in...I had the turbo replaced and the sump off and pickup replaced.. it then got its major service cambelt oil etc abot 6 months later, then it did about 6000miles( 12 months) and got serviced with castrol edge and new filter. I've only done about 4-5000miles since then.... its got a intermittent fault too (see separate thread) but it drove fine this morning. I also havent had the sensor light on for a week...
    I think I'll borrow my dads car for my paintball run tomorrow and then take it to volksmania on monday...leave the ownness on them to give me a guaranteed trouble free car back. regardless of cost..
    I rang a few vag specialists yesterday for a chat and one questioned the reliability of motorfactors coilpacks.... which i've fitted to mine...hmmm.
    I honestly dont think its an oil problem..more air/boost/spark problem and a faulty sensor...but I'll play it on the safe side as I dont want another £900+ bill.
    cant believe how ***** the 1.8T engine is. unreal....
    quite tempted by the new S3...I wonder how different the 2.0TSi engine is to the 1.8T lump of turd.
  9. M4KTT
    M4KTT Member
    96
    cheers. I'll stick my head under and have a look. I think I'll get it replaced with an oil change whilst its in for fault finding.. at least I'll have the option to take it back should anything happen.....
