DIS telling me brake light out
BigBen Apr 5, 2010
  1. BigBen
    BigBen Member
    68
    Hi all, my DIS constantly has warning telling me a brake bulb is out- orange illumination bulb in brackets with X through the bulb.
    All of my bulbs are fine so i am stumped and it is really annoying me-
    are there any known causes of this problem? Also on my DIS it often goes very red- like way to much colour and you can't really read the text- no lines through it which i know is the normal fault.
    Any thoughts appreciated
  2. aragorn
    18,444
    847
    If your certain its not the bulbs (including the high level) then its probably a faulty bulb monitoring box.
  3. BigBen
    BigBen Member
    68
    bulbs are defo all good. What and where is this box?
  4. aragorn
    18,444
    847
    its in the relay box, big double width relay thing.
  5. BigBen
    BigBen Member
    68
    Que me to sound dumb- the relay box as in the fuse panel - or the box where the ecu is :icon_thumright:
  6. BigBen
    BigBen Member
    68
    I found it. Trip to scrappie soon - do all audi have same one?
  7. aragorn
    18,444
    847
    Depends on the year, take down the part number and find a matching one!
  8. Nessy
    Nessy VW + Audi mad
    935
    88
    Before you assume the monitoring system is faulty, make sure all connections and terminals on the rear lights are clean and corrosion-free etc.
    In my experience cars with DIS don't like cheap quality bulbs either, so make sure that you are using 'premium quality' bulbs as they seem to be better finished and less susceptible to making a poor contact when in-situ.
    I used to use cheapo brake bulbs (Ring brand) from Wilko in my car but had several cases of the bulb only lasting 3-4 months before the DIS would flash, and sometimes a new bulb wouldn't stop the warning from appearing.....
    Then switched to Bosch bulbs and have had no probs since.
    It may be all a coincidence, but am convinced its all down to bulb quality more than anything else.......
  9. Geeman
    Geeman Low Life
    1,318
    Sometimes, my DIS comes up with a bulb failure warning when I turn my lights on. They are non-OEM HID's. It goes off after about 5 seconds though.
    Maybe a similar thing. Mine doesn't do it all the time though...
    It does it with the fuel too... stupid thing... I've got LOADS left... honest!
  10. Broken Byzan
    13,237
    465
    I have heard of the small bulbs in the cyclops light being the cause of this as they "wear out" as it were
