DIS Showing Door Open But Its Not
s3bow May 21, 2006
  1. s3bow
    s3bow Member
    381
    I've had this intermittently for a while now. The DIS is showing the door as being open when it is closed. This then won't switch the interior light off and when stopped, won't allow you to set the alarm with the fob.
    My brother (Audi Tech) says its a faulty micro switch on the door catch.
    Anyone else had this ?
    Chris.
  2. imported_Stewart
    imported_Stewart Guest
    It is a faulty microswitch, mine does it on hot days..
  3. s3bow
    s3bow Member
    381
    It seems to be worse on hot days too.
    Did you change yours ?
    Chris.
  4. imported_Stewart
    Not yet, i got a refurbished one off ebay, its not annoying me enough yet to spend half a day stripping the door down...
  5. god_thats_quick
    2,507
    It's pretty common, can do wierd things... my interior lights would pulse and the car would lock but it would go off a few mins later.
    It's not that hard to do and only takes max 2 hours if your careful - you don't need to seperate the door from the car just the inner frame from the skin there a thread or ten on here with what you need to do too.
  6. [ QUOTE ]
    Chris.
    [/ QUOTE ]
    You bet - a very common fault. I got mine replaced under warranty.
    Not only was it irritating, my concern was that the car wasn't properly alarmed, not sure if that was the case though.
  7. hamski
    hamski Member
    121
    I've got the same with mine. DIS shows door open and interior lights come on over bumps and round corners.
  8. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    [ QUOTE ]
    [ QUOTE ]
    Chris.
    [/ QUOTE ]
    [/ QUOTE ]
    I don't think the car will be alarmed properly as it thinks the door is ajar. When the same problem happened with mine the red LED on the door would not light, but the remote would still lock the doors. All the more reason to get it fixed.
    Mine was replaced under warranty too /ubbthreads/images/graemlins/tongue.gif
  9. s3bow
    s3bow Member
    381
    Mine's out of warranty. Stewart, how much did it cost you ?
    Chris.
  10. Defratos
    Defratos YouÂ’re Dethpicable!!
    2,232
    anyone know any old threads where this problem can be fixed?
  11. imported_Stewart
    It only cost me a fiver off fleabay, the guy had bought a brand new one then fixed his old one...
    Sorry I havent looked too closely at it but its something to do with the microswitch itself...
    I got the whole lock mechanism with the switch built into it...
    Maybe he stripped the switch down and repaired it, i dont know, sorry.
  12. god_thats_quick
    2,507
    A quote from me in another thread...
    [ QUOTE ]
    these two posts cover pretty much everything, I was going to do a better write up, but my camera was being a pain on the day that I actually fixed it.
    http://www.audi-sport.net/ubbthreads/sho...true#Post340661
    http://www.audi-sport.net/ubbthreads/sho...true#Post337282
    the other problem is there is no real point in listing the part numbers because it'll be different for each side and could be different for different cars, however Audi seem happy to help and gave me the right part.
    [/ QUOTE ]
    And if they don't clear things up a quick look on the below might answer any other questions but if not just ask.
    http://www.audi-sport.net/ubbthreads/sho...true#Post338516
    http://www.audi-sport.net/ubbthreads/sho...true#Post345088
  13. hamski
    hamski Member
    121
    I finally had the driver's door sensor replaced. But the DIS still does the same!! anyone got any ideas??
  14. DPM
    DPM Site Sponsor Site Sponsor
    5,033
    208
    Mines also doing this now, so annoying!
  15. JustSports
    JustSports Member
    88
    I had this when i first bought my car, this is going to sound stupid, but i closed the lock with my finger with the door open, then reopened the lock and then shut the door ! its been fine since !
    I think the lock just gets stuck, especially on hot days, perhaps just needs some grease / wd40 ??
  16. QUATTRO_REP
    QUATTRO_REP Diesel Power!
    229
    i had this last year, and yes it pissed me off a great deal with the interor lights being on after the car was locked and no alarm being on. i just hammered the door lock mech with WD40 and i havent had any trouble since. the hotter days really did make it worse tho.
  17. rickparmar
    rickparmar Active Member
    2,317
    12
    This is now happening to me :(
  18. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
  19. Smoke Breather
    Smoke Breather Member
    94
    And me, bloody hot weather! nothing a bit of a slam didn't sort out though.
  20. voorhees
    16,218
    2,033
    Something else to blame on global warming
