DIS retrofit - the washer level wire conundrum
ESD1711 May 19, 2013
  1. ESD1711
    ESD1711 Active Member
    691
    219
    43
    Ok, mucho apologies for ANOTHER dis thread, I know that these are already way too common but after heaps of searching, I'm not able to find what I'm after.
    Basically, got both my DIS and cruise stalk fitted today, no problems there.
    However, when it comes to the running of the wire to trick the washer level circuit, we are a bit perplexed.
    Have read heaps of 'how to' guides which talk about removing a wire from pin 1 in the blue multi plug..... But the plug which we found looked to be a sealed unit which my mate didn't want to go butchering without knowing for sure we were doing the right thing.
    Unfortunately, all the how to guides I look at with pictures, the image links appear to be dead on so I can't see if we are on to the right thing or not.
    So........ Ideally what I'm looking for is pictures of this part of the job, the plug, the wire which is removed and the replacement - the more the better.
    If nobody can help that, some detailed descriptions / instructions on this part of the job would be much appreciated........
  2. rizzini7
    rizzini7 Active Member VCDS Map User
    977
    153
    43
    I've got a link saved on my laptop will try and find it tomorrow if no one else has anything first
  3. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    If you lie in the footwell and look up towards the back of the instrument cluster you'll see a blue plug, secured in place with a swinging lock type plug, shouldn't be too hard to find.
  4. ESD1711
    691
    219
    43
    Cheers buddy! I've read about half a dozen how to guides tonight, but the ones with images all seem to be dead and the ones without dont give me the detail I'm after lol, just wanna be certain :)
  5. ESD1711
    691
    219
    43
    yeah I'm pretty sure we had the right plug - just didn't seem like removing wires from it would be particularly easy?!
  6. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Scotch lock a wire onto the correct wire and fix it to earth if your trying to turn the warning off. no need to remove the wire from the plug.
  7. rizzini7
    977
    153
    43
    Can you just cut the original wire and earth that?
  8. ukdan
    ukdan Member
    72
    Don't remove the wire, just either cut it and earth it or scotch another bit of wire to it and then earth it.
  9. Steve220
    Steve220 Member
    234
    15
    Don't scotch lock. I you're going to do it, do it properly and solder it! Scotch locks can cause overheating, shorting and fires. I Passionately hate the things.
  10. @udi A3
    1,819
    197
    Given the low load of the wire in question and the OPs difficulty/hesitation to remove the plug/wire, I highly doubt there will be any electrical issues and its a very easy addition to existing wiring with no fuss to complete the job.
    IMO if you are going to go to the trouble of soldering the earth wire, you should consider routing the wire under the bonnet and fitting the level sensor too. Most washer tanks have space to cut and fit such a sensor, but if not replace the washer bottle, as i did with my A3.
  11. ESD1711
    691
    219
    43
    Cheers for the replies so far folks - appreciated.
    JUst really wanted to make sure i've defo got the right plug / wire really. Fairly confident it is the correct plug but it just didnt look like it would come apart very easily which is what put the doubt in my mind.
  12. ESD1711
    691
    219
    43
    Had another look at it and having figured out how to remove the blue sleeve (i.e by removing the pink / purple retainer), had it off and the wire out within 15mins.
    Problem solved :)
    Just need to fit the repair wire and get it all coded up - nowhere near as bad a job as I was expecting to be honest.
  13. clarky87xx
    clarky87xx New Member
    13
    HI
    when fitting the earth wire does it need to be done with all the lower steering cowl off or can it be done after you have boxed all the car back up
    regards
    karl
  14. ESD1711
    691
    219
    43
    You'll be able to do it with the steering cowl in place, but you do need to remove the lower dash panel - comes off pretty easily, 2 minute job :)
  15. Newbos
    Newbos Member
    115
    It's a blue plug with an orange lock over the top. Just unlock and you will be able to slide block out and then like everyone else has said scotch lock onto pin 1. Make sure you have good contact because you will not want to be upside down in your foot well again unless your a dwarf lol!!!
    Then connect other end to an earth. I connected to a 10mm (I think ) about 2 inches away.
    Hope that helps.
  16. hades-
    9,481
    646
    just take the clocks out and get it that way
    easy to do no need to get in the footwell
  17. clarky87xx
    13
    Does anyone know where the wire actually goes from pin 1, is there a multi plug at the passenger side somewhere or is that wire direct from the wiper switch.
  18. hades-
    9,481
    646
    it heads to the pass footwell behind the kick panel
    where you can connect up for the low fluid sensor
  19. clarky87xx
    13
    is the multi plug marked or any certain colour wiring or will I have to do a continuity test to determine the correct wire
  20. TwedA4
    TwedA4 Member
    111
    hi guys, sorry to resurrect an old thread...
    I too am looking for this blue plug. i haven't had a chance to lie down in the foot well and have a look up the back of the dash yet, but is this the plug i'm looking for on the back of the clocks...?
  21. TwedA4
    TwedA4 Member
    111
    never mind... i found it! :)
