DIS READINGS
johnmandy Feb 29, 2012
  1. johnmandy
    johnmandy Member
    74
    Had a look around the site, but couldn,t really find what i was looking for.
    My mate as a beautiful deep red audi a4 170 bhp..... year 2007, anyway on his Dis, it gives him readings of his current fuel range, eg 350 miles left in the tank.
    Anyway to the point, i'm sure when i had his system in a previous audi i owned.... i was able to change what was readable in the DIS, miles per gallon, time driven etc etc..... now he reckons his DIS cannot be changed from showing fuel tank capacity.... i think he's wrong, so please put me right.
    He doesn,t have satnav in the car, it looks like the all red led ( i think) display, but does have MF steering wheel, he just as the ordinary concert radio, but is about to fit an off the shelf satnav to the vehicle.... obviously suitable for the audi a4.
    If you can help... Many thanks.
  2. lewie
    lewie Member
    285
    press the button on the end of the right hand stalk
  3. hades-
    9,480
    646
    as above he may or may not have it fitted DIS
  4. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    2,869
    1,522
    My S Line only has the range thing. From what I have read the SE got the multi function DIS but the S Line did not hence the high number of people who retro fit it.
  5. scotty76
    2,869
    1,522
    Oh and I do have the multi function steering wheel.
  6. Playsatan
    Playsatan New Member
    24
    As above the rocker switch will let you cycle through the options. You can add or remove categories if you go through the help function.
  7. Paul B7
    Paul B7 Active Member
    622
    34
    I have an 05 SE and the DIS is Multi functional so the above quote may very well be totally correct.
  8. ben.w93
    ben.w93 Member
    213
    22
    Have you had a play with VCDS? It has to be coded as being fitted with Board Computer on the steering wheel channel, mine stopped working when I was changing the coding on my steering controller when I was coding my retrofit cruise control. If not, have a play with the button on the underside of the wiper stalk and on the end of it.
  9. hades-
    9,480
    646
    he doesnt know if its fitted or not
    so there wont be a button on the underside or the end
  10. johnmandy
    johnmandy Member
    74
    Thanks all, it seems your all correct, he as the s-line.... so its only showing fuel range, no extra button on wiper stalk.
  11. Jeeves
    Jeeves quattronly
    116
    My S-line SE 170 from 2007 has a colour DIS with range, MPG, drive time etc. but i can't remember whether the S-line SEs had colour DIS as part of the pack. Maybe all the colour ones have the full suite of readings, whereas the red display only shows range?
  12. hades-
    9,480
    646
    dis colour etc etc were all extras from new
    the sline i have now had mfsw glovebox cd changer from factort but no dis the tight ****s
  13. scotty76
    2,869
    1,522
    Know what you mean Bez. My 2003 Leon had twin computers with all the settings but my "posh" Audi doesn't. Tight gits! :)
  14. Wrath
    Wrath Well-Known Member
    1,196
    41
    My 2005 S-Line has DIS, it wasn't retrofitted and didn't come with sat nav, cruise of MFSW.
  15. kite
    kite Member VCDS Map User
    677
    Option box ticked when ordrred
