DIS Only 1 memory.
AudiLeon Apr 6, 2010
  1. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    I've noticed when i press reset on my stalk, It's either on screen or off. No 1st and 2nd memory.
    Would there be a reason for this?
    Cheers.
  2. NHN
    29,576
    1,779
    Edited:
    Reason: Not enough tea & being thick.
    You have to flick through the settings in each computer with the rocker button on the end of the stalk, the reset turns DIS on/off with presses & flicks between computer 1 & 2 , if you hold it resets the DIS settings like mpg etc to zero.
  3. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    im sure second stage can be turned on and off with vagcom .
    the reset button turns on and off but also switches from position 1 to 2 on mine, think your thinking of the later dis nige.
    if your not getting stage 2 blacky then i guess its not activated
  4. NHN
    29,576
    1,779
    Damn it must be confused as Lea's right, oops, apologies, edited.
    You maybe right about turning computer 1/2 of as you can do this with the 8P, so have a look through cluster adaptations.
  5. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    You can disable all the 2nd memory features individually from the options menu, perhaps they've all been disabled :shrug:
  6. NHN
    29,576
    1,779
    Is that available on the B6 clusters as I dont recall seeing this in my S4, then again I knew ***** about technical stuff back then on these cars lol.
  7. 1wheelonly
    2,386
    112
    i assume stazatron is talking about the option in the dis and not on vagcom, the normal dis on a b6 staz dont give you all that you have on the later models, just range,mpg , hours etc on 1 & 2 thats it.
    2 can be turned off completely with vagcom
  8. AudiLeon
    2,250
    192
    I'll be popping vagcom on it tomorrow hopefully anyway. So I'll see if i've missed something about the second option.
  9. Staz
    6,206
    67
    Aha I see. Yeah I meant within the on-board menu you can disable individual choices from the screens, I didn't realise it was a new thing.
  10. NHN
    29,576
    1,779
    You've been suspiciously quiet for a while Leon, assuming all is good with you???
  11. AudiLeon
    2,250
    192
    All sorted, there was no coding on 19 at all.
    How it knew to do anything is beyond me!
    Coded it all in now, so the dash lights are on without lights on (find it hard to concentrate on the speedo without the bulbs) and got the memory 1 and 2 working.
