DIS Is Going For Replacement But Need To Lock Car
Martin82 Dec 17, 2011
  1. Martin82
    Martin82 Member
    71
    Im sending my clocks off as the DIS needs a new LCD screen. Ive read that i shouldn't lock the car with the clocks removed as it can make things go a bit nuts.
    Problem is the company I'm sending them too will likely have them a couple of days and i can't leave my car on the street not locked up (2000 S3 btw), i don't need to drive the car thankfully.
    Can any kind soul(s) offer me some advice on this?
  2. <tuffty/>
    21,685
    4,115
    Don't know about it going nuts but if you are worried disconnect the battery first then lock your car
  3. Broken Byzan
    13,237
    465
    Dash shouldnt make any odds to locking it. The CL is taken care of by the pump.
    The dash does the immo, so that means you won't be able to drive it , that's it. If you had an 8p, things might have been different
  4. TDIQ
    TDIQ 8L > 8P > 8V
    777
    I can confirm that I've locked my car with the clocks out without any problems.
  5. Martin82
    Martin82 Member
    71
    Sorry just to clarify, did you use the fob to lock it or the key?
  6. Broken Byzan
    13,237
    465
    It won't matter. The dash isn't included however you lock the car. The CL and immo are seperate
  7. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    I think its the ignition your not meant to turn on with the DIS removed.
    I would still lock it up with the key but that's just me being me.....lol
