DIS installed but 2 queries
vwgtiking Jul 11, 2013
  1. vwgtiking
    vwgtiking Active Member
    1,030
    I have posted in retrofit but no-ones seems to reply there so I will post here to.
    I have managed to install the DIS wiper stalk and enable it with vcds. I have the washer warning as expected but I am testing the buttons and nothing is happening? Is this because the washer warning is preventing it?
    Secondly I know which pin 1 to ground on the back of the cluster with the blue plug however just read about it and I need repair wire? Can I not use normal wire I have laying about. Also where can I ground it? Any pics?
  2. The patch wire is not a must, you can use a standard wire i believe, id double check the coding as ive had warning on for months since i fitted DIS (never got round to fitting ground wire) and always been able to use its functions with buttons,
  3. vwgtiking
    1,030
    The was 30100 and I tried 30200 which it didn't like then I did 30000. Should all clusters show various info.
  4. vwgtiking
    1,030
    Yeah I havent done coding under steering.
  5. hades-
    9,481
    646
    • 0?xxx: Steering Wheel
      • 0 = Standard (without Multifunction)
      • 1 = 3-Spoke Steering Wheel (Sport Steering Wheel)
      • 2 = Multifunction Steering Wheel with Radio Control
      • 3 = Multifunction Steering Wheel with Radio/Telephone Control
      • 4 = Multifunction Steering Wheel with Radio/Telephone/Voice Control
      • 5 = Multifunction Steering Wheel with Radio/Voice Control
    • 0x?xx: Options
      • +1 = Tiptronic
    • 0xx?x: Board Computer & Cruise Control
      • 0 = Board Computer & Cruise Control not installed
      • 1 = Board Computer installed
      • 2 = Cruise Control installed
      • 4 = Board Computer & Cruise Control installed
    • 0xxx?: Rear Wiper (Chassis)
      • 1 = Rear Wiper not installed (Sedan/Cabriolet)
      • 2 = Rear Wiper installed (Avant)
  6. hades-
    9,481
    646
    if you have mfsw and saloon ?
    what steering wheel do you have and saloon or avant ?
  7. vwgtiking
    1,030
    Saloon 3 spoke
  8. hades-
    9,481
    646
    there u go
  9. vwgtiking
    1,030
    Hi bez. Thanks. under steering or instruments in vcds. What should it be under both?
  10. vwgtiking
    1,030
    Perfect. Was 01001 now 01011 under steering and under instruments was 30100 now 30000 or 31000 if you want 2 memories but I never use the life to date one. Thanks bez!!!
  11. hades-
    9,481
    646
    and you can use any wire for the washer warning
    as b6 dont usaly have anything in pin 1
    when you have the dash out you will see a 10mm you can ground to
  12. vwgtiking
    1,030
    Ok thanks again bez. Clocks look easy enough to remove.
  13. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Memory 2 gives a more accurate mpg if you reset it each fill up
