  1. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    Hi I have the above at the top of my DIS all the time. Tbh I thought this was normal but on my road trip yesterday for some reason it started displaying the radio station and track name when using sd card on RNSE.
    After I turned the ignition off and back on it has come up with GW AUX again.
    One other thing is my aux input doesn't work (not that I'm bothered as I use sd card on rnse all the time).
    Is there any way to turn this off or is it a coding issue?
    Or because the Aux in isn't Working?
    Cheers in advance :)
  2. RobbieWebs
    1,031
    249
    No takers?
  3. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    73
    possibly due to the aux not working but im no expert, worth getting it scanned ;)
  4. winrya
    winrya Member
    52
    Did you retrofit the rns-e? If so then the aux needs to be modified to work. I'd imagine its this or coding that's your issue?
  5. TFSIer
    TFSIer 2.0TFSi Sport Sportback 2006
    39
    Have you got a Dension Gateway fitted ?
  6. RobbieWebs
    1,031
    249
    Thats what I'm thinking, cheers bud :)
    Yep it was retrofitted, don't think the Aux was done.not bothered about the aux tbh, maybe see about changing the coding to unable aux :)
    No m8 no Dension fitted. Funny but when I goggled it the Dension kit was the only thing it come back with :)
