  1. redbutcher
    redbutcher Member
    649
    I've done a search, but couldn't find the info so hopefully this isn't a duplicate post.
    In the DIS, flick the display round until you see the 'set', 'check' etc options, Select the 'set' option. You should see things like computer etc. Go to the small down arrow that is at the bottom of the list and select it with the control stalk.
    Two settings should appear - doors and windows. Have not played with the windows settings yet, but it looks like you can set up the convienence closing with the remote.
    If you select the doors option, you can choose if the selective locking is on and off and also if the auto-lock setting is on or off (doors auto lock above certain speed).
    I thought this could only be done with Vag-Com - so much easier setting it via the DIS :)
  2. bacardi
    bacardi Active Member
    1,139
    Wish mine had that, there are no doors and windows options in my DIS
    Would be good to have all customer customisation options in DIS, many BM's and Merc's have this now
  3. Kontraband
    Kontraband Active Member
    2,008
    yeah, I dont have this too... and my car is only 17 days old.
  4. redbutcher
    redbutcher Member
    649
    :think: - hmm, wonder why mine does then?
  5. Kontraband
    2,008
    ME TOO!!
    In fact, Im going to go look now... check I havent missed it.
  6. Kontraband
    2,008
    ok, the 2 options I have arent the ones you have...
    they are indications and reverse sensor
  7. redbutcher
    redbutcher Member
    649
    At least you've got something - just a shame it's different options though :(
  8. Kontraband
    2,008
    yeah, its weird we have different.
    I can change the tones of the reverse sensor with mine, and Ive forgot what the other one does.
  9. h5djr
    9,464
    1,770
    Mine is March 2007 and I can change the settings for the following:
    Auxiliary Heating/ventilation
    Clock
    Computer
    Speed warning
    Language - 6 options
    Units of measurement for distance, fuel consumption and temperature
    Parking aid - change tones
    Audi have obviously added further functions since mine was built.
  10. bacardi
    1,139
    why the F they don't let us upgrade our DIS like everyone else lets you upgrade software I don't know, its rather silly
  11. Kontraband
    2,008
    added some, removed others.
  12. redbutcher
    redbutcher Member
    649
    Very weird - anyone got the options that I have?
  13. JohnS3
    JohnS3 Active Member
    3,032
    The other one turns your needle sweep on and off.
  14. JohnS3
    3,032
    Mine's an early 07 car and I don't see those options. Didn't you turn lots of options on recently? Perhaps this is related??
  15. redbutcher
    redbutcher Member
    649
    You're right John - I did, and managed to screw up the boot opening as well at the same time so now I can only do it with the middle button on the remote :confused:
    It could well be related I guess - oh well.
  16. SteveTDCi
    SteveTDCi Active Member
    1,407
    Mines a October 2005 car and I only have the options on computer 1 & 2 and then I can only change what shows on the dis, such as mpg, km/miles etc.
  17. Kontraband
    2,008
    No it doesnt. The other one is called Indications and it turns on/off laptimes and speedo digital display
  18. mattandrew
    mattandrew Member
    977
    21
    Think I have messed up the boot opening as well, need to have a look into it. Did you have problems opening the boot after setting up the autolock?
    Matt
  19. cjp2k
    cjp2k Active Member Team Tango Audi A4 saloon S-line owners group
    266
    my boot opening is screwed too, sometimes opens, sometimes need to use middle button off remote,
    Booked in to audi see what they say in a few weeks time!!
    BTW mines a March 07 car
  20. phantom
    phantom On Boost
    1,750
    My extras are dials and lap times
    p
  21. redbutcher
    redbutcher Member
    649
    No, mine screwed up after trying to get the auto convienience closing function to work (you don't have to hold down the lock button to close the windows/sunroof if they are open when you lock the car). The convienience function doesn't work at all on mine - no matter how long I hold the button down for, the windows don't shut if the car is being locked, or they don't open if the car is being unlocked.
    The auto-lock was enabled on mine when I collected the car.
    It's really annoying having to take the key out of the ignition and having to press the middle button on the remote to unlock the boot!
    The microswitch works fine if the boot is already open. If I move the lock back into place with the boot open and press the button on the lid, it opens fine. It's just as soon as the boot is shut the lid button does naff all.
    cjp2k - let us know what happens with yours - mine just doesn't work at all though on the boot lid. Let me know if you get anywhere with yours Matt.
    All I remember hearing was a 'chunk' as the boot locked when I was doing some coding with vag-com - just wish I'd kept a note of the original coding - no matter what I do, I can't reverse it :mad:
