DIS Error Symbol
gaz_hughes Feb 24, 2006
  1. gaz_hughes
    gaz_hughes GumbyGaz
    20
    Hi,
    The other day, I got the brake light symbol pop up on my dash reporting a faulty bulb. So replaced it, but now i'm getting this symbol everytime I turn ignition on....
    Now to me it looks like brake warning, low pads etc. Is this correct?
    Just seems strange it's happened at the same time my bulb warning came one, coincidence?.
    I looked in the manual and couldn't find this symbol (I'm expecting somebody will post a page number of the manual and i'll look a complete fool /ubbthreads/images/graemlins/crazy.gif ) only the one the same as the picture with the broken bulb in the middle and the red one with an ! in the middle.
    So do I need my brakes doing? Or has the DIS having a bit of fun?
    Gaz
  2. HTC
    HTC Active Member
    3,428
    9
    Indeed, tis brake pads. But you'll have a fair few miles left in them.
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    yes, it is the brakes, though they probably have loads of life left in them. I'd give them a visual inspection to see how worn they are as these lights can come on fairly premature.
  4. Khufu
    5,704
    31
    lol, your a quicker typer than me HTC
  5. gaz_hughes
    gaz_hughes GumbyGaz
    20
    Wow, fast response!
    Cheers guys! Will get them looked at in due course then, got a few things to do so that'll be added to the list for a weekend.
    Don't suppose there's a way of turning it off so you can see Radio/Track Listings again or not?
    Thanks again!
    gaz
  6. HTC
    HTC Active Member
    3,428
    9
    [ QUOTE ]
    [/ QUOTE ]
    Great minds and all that. /ubbthreads/images/graemlins/beerchug.gif
  7. HTC
    HTC Active Member
    3,428
    9
    [ QUOTE ]
    [/ QUOTE ]
    You can unplug the sensor if you really want to. Bit cowboy tho.
  8. gaz_hughes
    gaz_hughes GumbyGaz
    20
    Hummm... I think I'll leave it then.
    Cheers though and cheers all for such quick responses!
  9. madvw
    madvw Active Member
    2,489
    can't you press the button below the speedo to clear the warning?
  10. dickys3
    2,954
    I think you can just press the button on the stalk to get rid of it.
  11. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    [ QUOTE ]
    Wow, fast response!
    Thanks again!
    gaz
    [/ QUOTE ]
    If you replace your brake pads, you'll soon see your Radio/Track listing! /ubbthreads/images/graemlins/wink.gif
  12. Khufu
    5,704
    31
    is the sensor a seperate clip in part or is it integrated into the pads? I dont have sensors on mine but its easy to see through the wheel with my alloys.
