DIS Display
andy203 Feb 26, 2014
  1. andy203
    andy203 181 BHP
    280
    61
    In relation to the 'DIS' display on the dash, is there a default display? I.e Clock or whatever. If not what display do the majority of people have displayed assuming that it's not displaying a route via Sat Nav system. If you have input a route/destination into the Sat Nav, does the 'DIS' automatically change to the route display?
  2. Schizophonic
    Schizophonic Well-Known Member
    960
    487
    Yes, with sat navigation enabled your dis will switch to Sat navigation view by default.
    As for me I need a constant reminder about my average miles per gallon
  3. andy203
    andy203 181 BHP
    280
    61
    Thanks for that info, the average MPG would drive me crazy, is there a default setting when sat nav not in use?
  4. andywil13
    andywil13 Active Member
    380
    68
    I have the DIS showing my fuel stats most of the time.
    If I am navigating I have the DIS showing the route until I actually need the map, leaving the main screen for music most of the route
  5. Mike071288
    Mike071288 Active Member
    287
    26
    Mines is on digital speedo with average mpg underneath or miles to empty if I'm low on fuel.
  6. Simonrich
    Simonrich New Member
    25
    I also have digital speedo with smaller instantaneous mpg at the bottom or miles to empty when fuel gets low.
  7. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,606
    1,190
    Digital speedo & average journey MPG for me
  8. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    957
    394
    +1
  9. Itguy
    Itguy Well-Known Member
    1,130
    450
    I want to get my S3 plugged into VCDS so I can get my oil temp at the bottom when I've got the digital speedo up.
  10. oufc1976
    oufc1976 Member
    237
    82
    What actually gets displayed on the DIS when in Sat Nav mode? Just an arrow and distance?
  11. STERLING VOID
    STERLING VOID Active Member
    145
    I am in the Fuel Efficiency setting most of the time.
    SatNav would be cool if I had the option, will this be available with an after market system?
  12. PDA3
    PDA3 Member
    65
    With regard to the pop up display, can this show speedo and mpg?
  13. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 saloon S-line owners group
    6,861
    2,088
    No....
  14. cemerson
    4,606
    1,190
    No, you get all the junctions/roundabouts displayed as you approach them, and a bar which decreases as you approach it (so you know distance to go), and some other info
  15. oufc1976
    oufc1976 Member
    237
    82
    Nice! Sad as it sounds, this is one of the things that I'm most looking forward to using. Never had a Sat Nav before. And certainly not an integrated solution. Very slick!
  16. cemerson
    4,606
    1,190
    The junction display in the DIS isn't as good or as accurate as the one on the main screen. If there is an odd shaped roundabout/junction, or the roads go off at weird angles, it isn't really shown in the DIS. The main screen shows the actual shape of the roads though.
  17. Andy1608
    Andy1608 Active Member
    615
    204
    43
  18. Joetidman
    Joetidman Well-Known Member
    1,134
    598
    So you can choose two different readouts on the DIS? Or does it just rotate through a variety of options?
  19. Itguy
    1,130
    450
    It has different screens which you can then select different things on. Most screens allow you to have a small section at the bottom which allows you to scroll through one item at a time of the trip computer, mpg etc
  20. coolguy
    coolguy Member
    144
    19
  21. illingworth22
    illingworth22 Active Member TeamMisano Audi S3 Audi A3
    476
    152
    43
    I have the Digital Speedo and I have Google Maps on the Sat Nav screen.
    Anyone know what the 3 things are on start up... Bottom right of the DIS..... they look like 3 Mice (as in computer mice)
  22. JohnM100
    957
    394
    Rear seat occupancy/seatbelt indicators
    illingworth22 likes this.
  23. AJB
    AJB Active Member
    206
    52
    They just tell you which rear seatbelts are done up. Empty mouse picture means that belt isn't done up.
    The front passenger seat has an occupancy sensor (I guess it needs it for the airbag), so the dash light for the seatbelt comes on if somebody is in the seat and the belt isn't fastened.
    The rear seats don't have occupancy sensors, but the idea is that you know which seats are occupied, so you can check they've all done their belts up.
  24. Andy1608
    615
    204
    43
    I did wonder what they were myself
  25. Migwire
    Migwire Active Member
    406
    132
    43
    Memory 1 on my DIS seems to reset itself every new journey I make. Is this normal for memory 1? If so I'm guessing you reset memory 2 if you want to watch mpg on say a full tank basis?
  26. cemerson
    4,606
    1,190
    Yes, memory 2 is user-resettable, memory 1 is journey reset. If you make a stop for less than 2 hours it won't reset it though.
    Migwire likes this.
  27. Migwire
    406
    132
    43
    I take it the efficiency program stats are the same as memory 1 then? As in they're reset every journey providing you've stopped for more than two hours.
  28. cemerson
    4,606
    1,190
    Not sure, I've not explored efficiency program that much to be honest.
  29. felsby
    felsby Member
    53
    12
    The junction display in the DIS has one, VERY useful feature: When you´re about to turn, a vertical row of blue blocks at the right appears - it counts down from 10 blocks to zero, thus indicating the precise point where you are supposed to turn.
    Also, if there are two side roads close to each other, these are shown with a double arrow.
  30. cemerson
    4,606
    1,190
    Yes, that is good. The one on the main screen shows exactly where on the junction you are with an arrow too, which serves the same purpose.
