DIS and other things
tdz840 Aug 12, 2008
  1. tdz840
    tdz840 New Member
    10
    I have a 2005 A2 2.0tdi SE Sportback and would like to retrofit DIS. Whats involved, the likely cost and the best place to get the parts? Has anyone produced an aide memoire?
    Also whats involved with retrofitting the RNE nav/radio thingy. Whats the typical retrofit costs and again has anyone experience??
    Thanks in advance
    Russ
  2. sat1983
    sat1983 Member
    848
    15
    DIS retofit has been discussed many times. Not worth doing, far too much work involved.
    RNS-E retrofit is easy enough if you have a double din radio unit. If you only have the single player then it is trickier and more parts are needed (hazard switch etc + cutting down your climate control unit either side).
    The RNS-E is typically worth between £500-£600. Just sold mine for £500.
  3. Issac Hunt
    1,162
    Ross Tech show a coding change for the addition of the on-board computer. If you have the full height display already then maybe you could just add the new wiper stalk and re-code it to enable it? It certainly works on the A4.
  4. TrickyLad
    TrickyLad is loving his new A3
    118
    audi garage in blackburn wouldnt even consider it when i asked about the DIS retrofit, despite being told when i bought it that any retro fit is possible at a later date.
  5. Issac Hunt
    1,162
    Audi dealers will usually only attempt jobs that are officially sanctioned by Audi themselves for warranty reasons. Eg they will fit cruise as there is an official 'kit' for doing the job but most wont fit an RNS-E as there is no official Audi kit or procedure.
  6. tdz840
    tdz840 New Member
    10
    Thanks guys for all your inputs - V helpful!
    Like the idea of the wiper stalk change (I have a full height display) and a recode that sounds simple and easy. Anyone attempted this on a 2005 or later A3?
    I currently have a concert single DIN unit so would involve a double dIN cage. Is the RNS-E a useful addition; what extras does it provide?
    Russ
  7. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Fully integrated DVD sat nav and radio with SD card slots that let you play MP3s.
