Dipstick tube
Bignick Jan 23, 2010
  1. Bignick
    Bignick Member
    165
    Managed to break my dipstick tube today while changing the thermostat, how dose the rest of it get removed? i gave up because of bad light. I will get a new one tomorrow, I'm hoping it will be self exsplanitary, but the way my luck has been going lately. Is it held in with a screw somewhere?:(
  2. Imteyaz
    Imteyaz 6th Gear
    535
    Dipstick tube is just' push-on' fit, expect more of it to break off when removing what is left! Try covering the exposed hole if possible to stop any further remnants of orange plastic falling down the tube and into the sump. Maybe wrap some gaffer tape on the broken tube before yanking it of to keep all the bits together?. Soften the new dipstick tube in hot water before fitting, it should 'click' into place.
    I had a similar problem when I was changing my thermostat, broke the dipstick tube (luckily I had read up so expected it to happen and had ordered a new dipstick tube too). A few weeks later, I took the sump off to check the oil strainer before changing the oil and found quite a few bits of orange plastic lodged in the oil pick-up gauze.... cleaned it all out using compressed air.
    HTH,
  3. tompearson
    tompearson It's all in bits
    219
    I did just that today as well. Not sure how to describe it properly, but the bottom end has a lip so that pipe it connects to sit inside it - the plastic tube is both inside and outside the pipe for about 10mm or so. I think it should just slide off, but everything I tried caused it to shatter some more. I ended up breaking it off in chunks whilst trying (and failing) to stop bits failing down into the sump. Apparently this isn't too much of a problem though as the bits won't get through the gauze into the engine.
  4. rossbrownlee
    rossbrownlee Ross_S4
    719
    Personally i'd be more concerned about it choking the strainer and causing oil starvation. I did the same a couple of weeks ago but luckily enough was just about to replace the sump & oil pump anyway.
  5. tompearson
    219
    I didn't think of that, but I don't think much went down, only some smallish pieces. The "not too much of a problem line" is an Audi one apparently and others have stated that the hot oil will break it down anyway, although I think I read a post somewhere about finding bits of the dipstick tube in the sump.
    Cars is in bits at the moment anyway and I need to put on stands to do the brakes so maybe I ought to think about removing the sump, or would an oil change be enough? Shame the thermostat didn't die a month or so earlier before its last oil change. Oh well...
  6. Bignick
    Bignick Member
    165
    Thanks for all the help guys i was going to do it today because the audi web site said they are open....... no such luck
  7. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,650
    534
    IVe got a brand new one sitting here mate. £15 posted if you want.
  8. HTC
    HTC Active Member
    3,428
    9
    They are like £3 or something from Audi.
  9. ruairi83
    1,650
    534
    i got one from agnew audi belfast and it was £18 all mate.
  10. HTC
    HTC Active Member
    3,428
    9
    You were done. I bought one from a VW dealer for a couple of quid if I remember. It was so cheap I ended up grabbing two.
  11. HTC
    HTC Active Member
    3,428
    9
    Maybe they were on special?
  12. ruairi83
    1,650
    534
    agnew audi in belfast usually charge alot more than across the water mate as few thing have been alot more expensive. Aw well it here if the guy wants it mate.
  13. swatchuk
    swatchuk Member
    313
    14
    i changed mine 2 weeks ago after snapping it. £3.20 from audi dealer
  14. mitch18
    mitch18 New Member
    27
    Iv just snapped mine!got to go collect mine from audi tomorrow. Hopefully the new 1 isnt as brittle lol
  15. <tuffty/>
    21,367
    3,932
    They all do it... have stock of the bloody things at the workshop as if you have to touch them they break... thankfully they are cheap... get yourself a dipstick too ... they are only a couple of quid
  16. mitch18
    mitch18 New Member
    27
    Yes true I didn't know I broke mine at first, think I broke it doing the N249 bypass only noticed when I I went to take the thermostat out ! New pickup pipe and another oil change in need lol
