Dipstick tube
Jay Jun 23, 2008
  1. Jay
    Jay Member
    318
    Broke this when changing the thermostat, managed to get hold of a new one but it doesn't seem to go on. I thought it would just slip on but doesn't seem to clip into anything.
    Is this a certain way it goes on?
  2. HTC
    HTC Active Member
    3,428
    9
    I take it you removed all the old broken plastic from the lower metal section. You know, the scary bit where you try not to drop any into the sump.
    I wasn't happy with how the new dipstick fitted. Indeed there was no positive click or else. It is held somewhat by the metal bracket that bolts to the inlet manifold, but previously mine leaked a little. I ended up using a small amount of silicone to secure the join
  3. h100vw
    h100vw Member
    218
    Bust mine doing the stat as well! :whistle2: The black tape I put on then is doing a fine job :undwech:
    Gavin
  4. Jay
    Jay Member
    318
    I'm sure the black tape must have melted with the heat.
    I 've just managed to push it into place after a long drive. I think it the heat from the engine must have loosened it up a little.
  5. RichA3Turbo
    5,089
    Damn dipstick tube. too easy to snap.New ones need some glue to hold it in place... But i figure im likely to snap it again so haven't bothered.
    Rich
