Dipped headlight pointing too high
heap1000 Dec 19, 2012
  1. heap1000
    heap1000 Member
    158
    Ok i changed ny passenger side dipped beam light and when looking at the car head on with the lights on the one i changed seems really bright and gets into your eyes. Whrn i shine them on a wall the one i changed seems to be poonting high and slightly to the left.
    I was quitr carefull to make sure i took note of which way the bulb went in when i swapped it over.
    Is there a certain way they go in? Whats the best way to get it back right?
  2. monopole
    monopole Well-Known Member
    1,154
    470
    Check to see if the bulb is seated correctly, they can be installed but not seated flush, which results in the symptoms you give.
  3. Best84
    Best84 Member
    137
    sounds like its upside down...i did the same thing, easy done i guess with the ridiculous amount of space you have lol
  4. heap1000
    heap1000 Member
    158
    Very true!you need a small child to help you fit the damn things! Will have to take a look at it this weekend when i can get some daylight! Well thats if the world does not end tomorrow!
  5. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Yip classic case of bulb in wrong way round.
