Dip stick stuck
bad-vw-boy Mar 3, 2010
  1. bad-vw-boy
    bad-vw-boy Member
    72
    Just tried to check the oil and the dipstick got stuck managed to put it back but being fairly new to these cars not sure if there is a special way to remove them, also what oil do you guys recommend?
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,764
    661
    When I replace the dipstick on my 1.8 T as the last owner somehow damaged the last one, I end up using sanding the top of the dipstick with a bit of wet & dry to make it easier to remove.
  3. bad-vw-boy
    bad-vw-boy Member
    72
    I can't even remove my dip stick it seems to get stuck at the end its a v6 s4 engine if that helps
  4. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,775
    33
    They are just a bit tight. Should come out easily enough given enough pressure.
