Dip in power
Wilts Aug 28, 2012
  1. Wilts
    Wilts Member
    100
    Hey guys this has happened afew times and its only in 4th but mainly 5th gear i go along the back roads on the way home from work and im doing around 40-50 mph and its going up hill slightly and my a3 dips in power or goes to die and then shoots off agin but its less than half a second so it happens very quick its about 20mins into the drive hope some one can throw any ideas, many thanks.
  2. Wilts
    Wilts Member
    100
    Its just done the same thing on the way to work but not as bad in second gear and car was cold only been running for 2mins
  3. <tuffty/>
    21,016
    3,780
    Have you scanned for fault codes yet? Pressure drop or similar from a leak maybe which would throw a code... usual checks for split pipes etc required no doubt... it's at that age...
  4. Wilts
    Wilts Member
    100
    Yea i did them fault codes not long ago but i cant remember if it was doing it then?
  5. <tuffty/>
    21,016
    3,780
    Typically if dropping power its a 'soft limp' type of thing which is normally due to a pressure drop from a leak... I'd be checking the PCV pipes etc under the inlet mani as these go regularly..
    Get a smoke test if you can... a lot a garages will do this type of test
  6. Wilts
    Wilts Member
    100
    Whats a smoke test bud? And il get on and check all pipes as you said.
  7. <tuffty/>
    21,016
    3,780
    Smoke test use 'smoke' and a small amount of pressure to find leaks in pipe work...
  8. Wilts
    Wilts Member
    100
    Umm looks like a good idea that, dont know anywhere that does that round torquay
  9. <tuffty/>
    21,016
    3,780
    A lot of garages do have the kit... might be worth a ring around :)
    We use it on almost every 20v that comes in now lol... most power loss issues seem to be attributed to split pipes these days...
  10. badger5
    9,431
    1,975
  11. Wilts
    Wilts Member
    100
    Had it on scanner lastnite and its come up with 16486 mass or volume air flow circ? So would this be mass sensor thats causing this problem?
  12. <tuffty/>
    21,016
    3,780
    16486/P0102/000258 - Ross-Tech Wiki
    16486/P0102/000258 - Mass Air Flow Sensor (MAF/G70): Signal too Low
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Loss of Power
    Possible Causes
    Wiring and/or Connector(s) from/to Mass Air Flow Sensor (MAF/G70) faulty
    Possible Solutions
    Check Wiring and/or Connector(s) from/to Mass Air Flow Sensor (MAF/G70)
    Check/Replace Mass Air Flow Sensor (MAF/G70)
    Special Notes
    In MY 1995-2002 (?) in Europe at VW-diesel-cars G70 had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)
    Is the car mapped? any work you had done recently?
  13. Wilts
    Wilts Member
    100
    Yea bee mapd stage1 i did think it could be tb untill i put scanner on and it came up with that, so should i clean the mass sensor and go from there?
  14. <tuffty/>
    21,016
    3,780
    Has this started happening since it was mapped or has it been mapped a while with this being a recent problem?
  15. <tuffty/>
    21,016
    3,780
  16. Wilts
    Wilts Member
    100
    Yes its only just started it got mapd along time ago, iv just had a look and the big pipe on side of dump valve was on the edge of coming off not sure if that would cause the problem aswell?
  17. <tuffty/>
    21,016
    3,780
    Possibly... I would check the engine over and look for and sort any of these issues out first then reset the fault codes and see if they come back
  18. Wilts
    Wilts Member
    100
    Yea ive read that link above so gunna check the mass plug pins wire harness etc and really have a look at everything in engine bay and just go from there and see what i find, many thanks for your help as always il report back saturday!!
  19. Wilts
    Wilts Member
    100
    I think the problem has gone now ive put a metel clip round that dv and it didnt do it at all yesterday but i will still check the wires and pipes on weekend to make sure. Many thanks tuffty for your help as always i wouldnt know what to do.
