Dimming DRLs when Indicating
Tay May 25, 2013
  1. Tay
    Tay Active Member VCDS Map User
    449
    54
    Hi All,
    I'm looking for a bit of assistance with the coding to make the DRLs dim when indicating on a 2008 S Line. I'm going to have a go at sorting this tomorrow for my mate and all I can find info on is the "wink" feature which appears to turns the DRL off completely when indicating.
    I'm guessing if this can be done, can the brightness of the DRLs be controlled so they dim by say 50%?
    Any help with this would be very appreciated!
    jamin128 likes this.
  2. riggssuzuki
    riggssuzuki Active Member
    496
    57
    Mine is set like that as standard. They dim when the indicator is on.
  3. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,027
    729
    as said, they shouldnt turn off when indicating, they should dim.
  4. golfather1
    golfather1 Active Member
    150
    43
    I done mine with VCD now they don't dim when indicate & yes you can increase the brightness
  5. Tay
    449
    54
    Could somebody possible send me there standard long coding for central electrics module? Need to try and get to the bottom of this, the car does not has LED wink active but they turn off when indicating :s
  6. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,301
    390
    Do they go off at all if they dont dim? If not this could prove do be dangerous as the bright LED mask the orange of the indicator. This is the purpose of them dimming.
    New MOT rules will cover this at some point.
    ScottishA4B9 likes this.
  7. jamin128
    jamin128 Member
    208
    Anyone now where to enable dimming and increase brightness on VCDS?
  8. RAF_S7
    RAF_S7 Well-Known Member Team V8 Gold Supporter Team Sepang Black Edition Audi S7
    739
    405
    Hi Guys,
    Apologies for hijacking the thread, but seems appropriate to post here :)
    I have a 2010 A6 S-Line Quattro with the adaptive Xenon's and LED DRL strip within the headlights. They do not dim or switch off on indicate (Factory standard on the Le Mans?)
    I have VCDS (newbie user so be gentle!)
    Could someone give me a line by line step on how to code to force the DRL's to dim on indicate?
    Should add that Ive not been able to find a "wink" option within the hidden MMI 3G menu structure...
    Much appreciated.
    John.
  9. benjie
    benjie Well-Known Member
    1,223
    304
    I hope the following helps, these are for B8 platform cars, but will probably work for the C6 A6 platform too - worth a try.
    Disable LED 'wink' on turn signal
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
    Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
    Adjust LED brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code shown by VCDS)
    [Adaptation - 10] -> Channel 3
    Set between 5 and 100
    Not my info, shamelessly stolen from this thread.
  10. RAF_S7
    739
    405
    Thanks Benjie, will give that a go tomorrow.
    John.
  11. benjie
    1,223
    304
    Happy to help, any luck?
