Dimensions of 19" wheels that will fit?
mattfinn Aug 25, 2012
  1. mattfinn
    mattfinn Smoking is good for you
    833
    Hi all, i've searched through pages and pages and can't track one down for the B8.
    I am looking to change to 19" wheels in the near future and didn't realise what a minefield it is!!
    Getting the size as recommended is: 19 x 8.5 ET43.
    My question is, what other dimensions will go on the B8. As yet it is not lowered but will be going 30 - 40mm lower.
    Thanks for looking, a pic of your B8 on some 19"'s wouldn't go amiss
  2. Bracer
    Bracer Member
    49
    I'm running the said 19 x 8.5 ET43 but I also have H&R Sport Springs which has lowered the car by 1.3/4"
    I am also using 10mm spacers at the front and 15mm ones at the rear so that in effect makes an ET of 33 front and 28 rear but I do rub a bit on the heavier compression bumps.
    I've heard of people running 20 x 10's with no I'll affects.
    mattfinn likes this.
  3. mattfinn
    833
    Thanks matey! It's wheels like yours that i'm after, and mines the same colour too.
  4. Bracer
    Bracer Member
    49
    Cheers bud, I'll take that as a huge compliment !
  5. steadytdi
    steadytdi New Member
    I am running a set of BBS CKs on my s-line which are 20" x 8.5 and they sit and ride perfect
  6. Bracer
    Bracer Member
    49
    :sign_pics:
  7. steadytdi
    Sadly they dont photo well been black, once tyres have worn will put a lower profile tyre on and change the colour
  8. steadytdi
    Also had my grills sprayed black and number plate recess shortened
    Still to come, wheel colour change, some kind of low but unsure which way to go, retro fit parking sensors and hopefully get hold of some buckets like in the background of one of the above photos
  9. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    Do you have to use spacers when you drop?
  10. Mcdubber1
    Mcdubber1 Member
    255
    People only do it so the wheels fill the arches better and can also improve handling because of the wider track but you don't have to.
  11. NVM
    NVM Member
    98
    67
    19x8.5 with a 15mm drop is perfect. I did try 20x10.. but they rubbed without the drop
