Digital speed readout.
rs13219 Jan 7, 2006
  1. rs13219
    rs13219 Member
    114
  2. madvw
    madvw Active Member
    2,489
    doa google or search on here... this works on so few cars now, i'm suprised that people still sell it on ebay..
  3. rs13219
    rs13219 Member
    114
    Can't seem to find anything? What models does it work on?
  4. dickys3
    2,954
  5. scoTTy
    scoTTy Active Member
    1,962
    It works on the previous A3 models, TT, previous Golf, etc. Doesn't work on B6/7 A4's or new A3s.
  6. rs13219
    rs13219 Member
    114
    What about b5's? Can using this menu have any negative results?
    Cheers, Rob.
  7. dickys3
    2,954
    [ QUOTE ]
    Cheers, Rob.
    [/ QUOTE ]
    May work.. Give it a try! Nothing to lose!
    You cant do any harm with it! Its read-only...
  8. rs13219
    rs13219 Member
    114
    Cheers for the responses will have a look?
  9. Nessy
    Nessy VW + Audi mad
    837
    56
    [ QUOTE ]
    Cheers, Rob.
    [/ QUOTE ]
    It works fine on the B5, I'm always using it when on the go to see what speed I'm actually doing rather than rely on the speedo needle.....
    Also works fine on a '95 A6,as it has an almost identical climate control display.......
    As it is a diagnostic feature IMHO using it can't do any harm.....
    /ubbthreads/images/graemlins/wink.gif
  10. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,699
    157
    Hi,
    I have just tried this using the climate control in my A6.
    I tried the C1 - System malfunction - displayed as a Diagnostic Trouble Code (DTC),
    the result - 0 37 to which i would presume is the code 03.7??
    However, all the codes listed only go upto xx.4!!
    does anyone know what 03.7 code means if anything?
  11. A3-frankie
    A3-frankie Member
    118
    can you only get a speed reading in knh then?
