Difficult gear change when cold
Kevint Sep 24, 2005
  1. Kevint
    Kevint Active Member
    1,182
    Advice please...
    For the last couple of months I've notice changing gear from first to second requires more force than usual, and it's getting worse, it's getting the point where I feel as though a *crunch* might be coming next.
    This only happens first thing in the morning when the car is cold and goes away as soon as it has warmed up, perhaps 2 or 3 miles of driving, it never happens again during the day, and again, only in changing from first to second.
    Car has covered 85K but had a new gear box at 56K /ubbthreads/images/graemlins/shocked.gif
    Any ideas?
    Kev.
  2. Replace Gearbox oil. Mate had same problem and it went away after he had this done.
  3. imported_bubstar
    imported_bubstar Guest
    [ QUOTE ]
    [/ QUOTE ]
    Yep . I'd 2nd that /ubbthreads/images/graemlins/ok.gif
    Deff worth a go.
    BUB
  4. EnzoS4
    EnzoS4 Member
    200
    I had a similar issue - when in traffic on hot days I had trouble going into 1st at stand still and from 1st to 2nd, all other gears are fine. Audi suggested selector bearings need replacing which is a known issue on S4s, for a £2,000 bill I bet its a known issue. Oh and the clutch was tested and found to be in good health.
    Anyway took the car to AMD, replaced the gearbox oil and its alot better now. I still have the issue now and then but not as often
    Good Luck
  5. m_o_w_g_l_i
    m_o_w_g_l_i Member
    43
    What would you fellas recommend then? I've used castrol (?) synthetic in the past but I've heard a lot of good things about Amsoil synthetic.
