different mass air sensor?
Discussion in 'A4/S4 forum(B5 Chassis)' started by brfoos, Jul 10, 2003.
  1. brfoos
    brfoos New Member
    Jul 10, 2003
    hi this is my first post. I own a 98 a4 1.8t, i have done many mods including chip, full exhaust, upgraded injectors, t3 turbo, exhaust manifold, bov, electronic boost controller, and a turbo timer. my question is that i just burned out my mass air sensor i was wondering if anyone knows if i can get a stronger one built for more boost that i can use or maybe a blow through one not sure many thanks
  2. Advert Guest Advertisement
  3. Gambba
    Gambba Active Member
    Jan 14, 2003
    1,361
    I have heard of stronger MAS units being used from vehicles like fords and things like that, but I am not sure of the full details. I know that there isn't one you can just purchase, fit and away you go though.
    Sorry I can''t help anymore than that.
  4. brfoos
    brfoos New Member
    Jul 10, 2003
    my friend is looking into using the maf from a rs2. he found out that someone was using it and it worked great
  5. excursion
    excursion Member
    Feb 25, 2003
    740
    Hello mate,
    Although the Audi MAF's are very sensitive, the charge velocity through the standard unit with the increased CFM of the T3 will surely be pushing it past it's limit.
    Get your calculator out and work out standard airflow through the maf and then calculate an increased bore size, obtaina bit of aluminium tube suitable and install your maf unit on this /ubbthreads/images/graemlins/smile.gif
    Nice setup BTW, i'll be making my own manifold and exhaust laster on this year and installing a T3. What sort of psi are you running? standard pistons or 225 versions?
