Different brake options
auroan Oct 14, 2008
  1. auroan
    auroan Active Member
    1,669
    Some of my previous cars have been based on the Mkiv golf chassis (Bora, octy vRS)
    A cheap upgrade for the brakes on the (288mm) was to put on 312mm carriers and 312mm discs. I've never really got to grips with what you can put on B5 A4s.
    Is their a similar "cheap" upgrade which sees the gains that the 312 setup gave over the 288. Also I mean cheap as in not having to change the calipers.
    Danny
  2. PaulJC84
    PaulJC84 Owner
    2,921
    17
    TT or S3 carriers allow 312mm discs from either the A6 or A8 to be fitted.
  3. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    Carriers are about £80 iirc
    Has anybody done this conversion as I'm very tempted but want to here from somebody that''s done it before ordering the parts up
  4. aragorn
    18,612
    872
    ive not done it but i've looked into it
    You need TT or S3 caliper carriers, vagparts do them for 90-100ish or you might be lucky at a breakers.
    then you need a pair of 312mm disks from B6 A4 or A6 (they're the same, brakeworld part number rs3630 if you wish to cross-reference them)
    You keep the standard A4 caliper and pads.
  5. auroan
    1,669
    Thats what I'm looking at. Didn't know that the S3/TT carriers fitted ? That means I've got a much much bigger range of vehicles to look for in scrappers (Leon cupras, Octy vRS, V6 golf etc etc)
  6. aragorn
    18,612
    872
    yup all the later A4s (ie B6>) and the B5 S4 and RS4 use a wider bolt pattern, but the A4 B5 uses the same as the TT golf etc
    The only problem you find at breakers, is that they know the carriers, calipers disks etc are sellable as a kit for £200 or whatever as an upgrade for golfs et al, and so most wont want to just sell you the carriers!
  7. PaulJC84
    PaulJC84 Owner
    2,921
    17
    I have done this upgrade. Is pretty good, but I found my standard brakes pretty decent as well.
  8. auroan
    1,669
    Yeah, my brakes would be ok if the car wasn't 1500Kg (2.8q weighs a bit:()
    I was just going to go to a walk around scrappers and try my luck. Can't do much yet as I'm running 15" rims until I can get some decent 18"s sorted.
  9. PaulJC84
    PaulJC84 Owner
    2,921
    17
    Yeah you will need 16" min to fit the 312mm ones.
